After several trips with my Titan 52 gal. tank, I can say I am happy with it. Just got back from a trip to Calif from my home in Idaho, and it sure is sweet to never have to think about a fuel stop and only stop when and where you want to.
I do have some feedback for anyone using the Titan 52 gal tank with the stock sending unit.
1. Due to the sender being mounted so low, and there being so much fuel above the top of the float travel, it will go over 300 miles before the gauge ever moves off of full. This also means that all of the "Range XXXX" readings are pretty questionable during this time (see pic). This was at an average of about 20mpg, so the first fifteen gallons are gone when the gauge drops to the F mark, so the remaining 37 gallons are now what sits between F and E on the gauge. So, when you hit the half tank mark, you have about 18 gallons left, not half of 52, so be aware.
2. When the fuel level drops below the 1/4 tank mark, the Range drops about 2 miles for every one mile travelled (running 80mph at 20mpg avg). If you believe it when the "Range" tells you that you have 400 miles of fuel at 1/4 tank, you could find yourself running out if there isn't a fuel station closer to 200 miles down the road.
Despite the need to compensate for the fuel level/range discrepancies, it sure is fine to be able to drive over 12 hours without a fuel stop (with no load).
I am looking forward to hauling the 5th wheel and not needing to find fuel between overnights, since we usually only go 300-400 miles a day when towing.
