Im running the Full Carli Pintop system with progressive leafs and king shocks on factory bags and i honestly havent seen the bed drop any more than factory and if you go to Carli website they say the leafs maintain factory payload. the ride of course is way better.
I thought I had read on there it reduces payload to a light 3/4 ton…
Did you notice any loss in stability compared to stock? My fifth wheel has about 2500-3000 lbs of pin weight depending on how heavily I’m loaded and I’ve been considering the Thuren rear leaf springs to go with the 1.75” front level. I already have 5000 lb bags and cradles and am looking to soften up the rear, it gets stiff in a hurry over bumps.You will lose a noticeable amount. I have thuren rear leaf springs and 5000lbs bags on daystar cradles. Max payload I need 75psi to level back out. I tow quite a bit and most I've had so far I was at 25,700ish combined. No problem towing and a lot better ride empty but you will want air bags.
Who makes your springs?I went with the fully optioned ALAS for my 3500 and I couldn’t be happier with how it turned out. They have two different sets of leafs, one for the ALAS (retain factory) and the other without which lowers payload.
It runs the bags dry during normal operation allowing the suspension to utilize the progressive leafs.
