3500 cab chassis vs pickup frame
kvp
Dec 1, 2021
Wondering if the frame/chassis is the same from the cab forward on a 2022 Ram 3500 pickup vs 2022 Ram 3500 cab & chassis.
Reason I ask is when using the online truck builder the same options are not available between the two. More options in the pickup.
I'd think the cab would be the same between the two, so that baffles me.
I know the c&c has straight frame rails behind the cab, as opposed the the hump over the axle on the p/u.
I also want to put a front hitch on the c&c but don't know if the frame is the same. Torklift has a hitch for p/u but can't say if it will work on the c&c.
Thanks, Kevin
Nope 3500-5500 C&C different frame front hitch is not the same same with plow mounts they are different vs the 2500/3500 from what i have seen
