- Joined
- May 29, 2020
I expect great things with the new engine something about straight 6 engines that just works great and usually extremely reliable
Hey i once saw a 2000hp funny car that was an inline 6 at the drag strip so i mean anything is feasible with enough moneyAbsolutely, it has amazing potential… as long as we don’t have delusions about what is feasible.
They are claiming 20 mpg in the Wagoneer. I'm only seeing 10-13mpg so 2x what I'm seeing isn't that much of a stretch.No way will the fuel economy be 2-3 times that of a hemi, especially with 100hp more. HP takes fuel and it’s not feasible to expect that level of efficiency. 10% is probably a stretch, if any gains are noticed.
What's the difference between that and the Hemi. The Hemi is an aluminum block just like the Hurricane is. You can't have aluminum cylinder walls without a coating or sleeves.The 3.0 was not designed as a heavy truck engine, aluminum cylinders for starters.
The 6.4 is not an aluminum block.What's the difference between that and the Hemi. The Hemi is an aluminum block just like the Hurricane is. You can't have aluminum cylinder walls without a coating or sleeves.
What will the HD get then? If the Hemi is discontinued that leaves the Cummins as the only engine option.
Can you imagine a 3.0 in a truck pulling a 10,000 pound camper? That thing would be spun up to the max, working it's butt off to move the weight!
Apples to oranges.They are claiming 20 mpg in the Wagoneer. I'm only seeing 10-13mpg so 2x what I'm seeing isn't that much of a stretch.
2jz, RBs, BMWs S54, B58, Jaguars XK 6... There are some phenomenal in line 6 engines out there. Sure they may all have failure points, every engine does but its a proven design that works extremely well and can sound even better.HD trucks don't follow the same rules. The 6.4L Hemi will stay in them for a long time.
Not so much the RPM, but the compression and boost they have to run to make that level of power in 3 liters of displacement is nuts. There is no way those engines will live as long as a large V8.
Except for the ones that aren't. The Jeep 4.0 for example. Terrible fuel economy, oil leaks galore, crank sensor failures, heads cracking between #2 and #3 cylinder, gasket failures, etc. etc. I guess the Cummins has been overall very good. Can't really think of any other I-6 engines that have been great. Maybe Mercedes had a couple back in the old days.
4.9 Ford, 225 slant 6....2jz, RBs, BMWs S54, B58, Jaguars XK 6... There are some phenomenal in line 6 engines out there. Sure they may all have failure points, every engine does but its a proven design that works extremely well and can sound even better.
Have ask somebody with a hemi in a Wagoneer what they get, I took one home 3 years ago but never kept track.Apples to oranges.
What would the 6.4 get in the Wagoneer? That’s a direct comparison.
What your getting and whats it’s capable of are also two very different things.
