I have a 21 dually. When not towing I air down to 65/30 front/back using the load inflation table recommendations. I have had several people comment on how good the ride is. I have rode in a couple of 2500s and can't say the ride was any better. The bigger question is what you are planning on using the truck for? At one time Chyrsler published tire pressures for both loaded and unloaded situations. I am sure some lawyer recommended that they only put the loaded pressures in the door because some dummy didn't air up the tires and rolled his truck while hauling two tons of gravel.
Eeeeehhhhhhh.
I also have a 21 dually. I also air down my tires to what you list above in your post when not towing.
Does the TPMS trip when you go down to 30psi? I ask as I have a 2500 and am looking at going to a 3500 dually,
Where can I get the Alpha OBD?3500+ have TPIS, not TPMS so they won't issue an alert.
It can be changed with AlfaOBD.
I used JScan to change it to TPMS and also the trigger pressure to 30 psi. When I tow in the fall, I change the trigger pressure to 65 psi as per door sticker pressure. I use JScan as I wanted something that worked with iPhones.Where can I get the Alpha OBD?
noticeably stiffer. just swapped my 2019 2500 for a 2022 3500 due to payload needs. in wife's first ride she commented on it “riding rougher than the old truck”. once it’s loaded down there isn’t much difference though.Whats the ride difference between the 2500 and 3500?
Lower tire pressures when not towing and air assist make for a better ride. Good as the 2500? Not likely, but mine is WAY better than my 04.5 2500 ever was.
Thanks, great to hear this from folks that actually own both. That's what I found too when I test drove some 3500's with factory air. I was ordering a 22 and thought I might want to step up to the 3500 to "future proof". I was driving an 18 2500 CTD with factory air suspension at the time and it is a very noticeable difference. I ordered a 2500. But if I'd needed the extra capacities, I'd have for sure lived with the harsher suspension in a 3500.noticeably stiffer. just swapped my 2019 2500 for a 2022 3500 due to payload needs. in wife's first ride she commented on it “riding rougher than the old truck”. once it’s loaded down there isn’t much difference though.
