LateToTheParty
Didn't want to come
Have any pics of that 3rd gen kit installed on a 4.5 gen like we're discussing here?If you need to buy a leveling kit, consider Blackhorse racing's product for Dodge Ram 2500 3500,3'' Front & 2'' Rear
I still need to install my RC leveling kits. Did you find the instructions accurate when it comes to indexing the isolators? I’ve seen some say that on the passenger side you should align the it isolator on the D and not the P for passenger. Curious what you did?my truck with the 2.5" rough country level.
As already mentioned, it is due to the modifications. As soon as you get your wheel back close enough to center so that a moderate turn followed by returning to approximately center, will clear that message. You could do it yourself or simply wait until you get the alignment done. No need to mess with the stealership.Hello everyone. Hoping someone can chime in on a similar situation, if you have had it. Had the Thuren 2" installed with Fox shocks, sway bar and track bar. After install steering wheel was offline, barely. Truck had no pull left or right on flat road, and rides well. Wanted to drive it a bit before getting alignment checked and steering corrected. In the process I got a "service electronic stability control" message, but had not gone away. Took to dealer, who told me there is nothing they can do, unless I pay for service out of pocket, as I have "voided" my suspension warranty due to the leveling kit. They checked code and it appears to be due to the "steering sensor not in range." Anyone info is appreciated. TIA
For 2” lift Track bar shouldn’t be adjusted, drag link can be though.. Very easy adjustment to make, I did my own and got it to my preference on the 2nd shot.Just adjust your track bar and it'll fix it like these guys said. That track bar adjustment won't mess with the trucks alignment, it'll only center the axle
No, this isn’t the problem.Just adjust your track bar and it'll fix it like these guys said. That track bar adjustment won't mess with the trucks alignment, it'll only center the axle
I’m not sure if you meant drag link but adjusting the track bar won’t solve the issue, the drag link needs to be adjusted as others have mentioned.Just adjust your track bar and it'll fix it like these guys said. That track bar adjustment won't mess with the trucks alignment, it'll only center the axle
Did you upgrade shocks or just use the shock extensions? Also, how's the ride quality? I'm having this same kit installed on mine this week and am curious.my truck with the 2.5" rough country level.
nkI put an inexpensive 2.5" leveling kit and new adjustable track bar on my truck from Rough Country and now i hear a clunk when I hit a large bump. I suspect it's the shock extension brackets that came with the leveling kit. I may buy new longer shocks and pull off those brackets and see if the clunk goes away. (I guess you get what you pay for!)
I did use the shock extensions that came with the kit. I suspected they were the cause of the clunk so pulled them off and bought new, slightly longer, billstein shocks. Clunk remains... so I'm still stumped.Did the clunk noise ever get fixed? I have this with a Thuren setup and nobody can figure out why it’s making clunking sounds over any kind of bumps. Had three different shops check for anything loose and all of them came back saying all was good. It’s strange.
nk
Is the clunk on compressions or extensions?
I ask because my truck clunks when I drop (extensions) a single tire off of something or into something quickly. Such as a one tire off a curb or into a pothole. I think I have determined mine to just be the limit of the front coils in their buckets or something such as that.
Hitting bumps (compressions) are smooth and no noises.
Also, coming off a curb with both front tires at the same time there is no clunk. This doesn’t cause the same extension as dropping one tire off. Additionally, driving slowly over bumps and curbs gives no noise
Mine does it when I hit a somewhat bigger bump in the road going 15 ish mph. Usually going through an intersection where the two road surfaces don't meet flush or there is some kinda drop off between the 2 surfaces. Not sure that's a great explanation...Is the clunk on compressions or extensions?
Also, coming off a curb with both front tires at the same time there is no clunk. This doesn’t cause the same extension as dropping one tire off. Additionally, driving slowly over bumps and curbs gives no noise either.
Mine seems to be both…or I guess pretty much any kind of bump or hole. Driving on the highway or main kind of road it’s very smooth but through a residential that doesn’t have the greatest of streets, it’s making all kinds of noises.
It does seem like the tire drops kind of hard when hitting a hole (mechanically stupid so not sure how to describe it) which is odd in my mind with my having the Thuren coils and Fox 2.0 from them. Going over cracks in the road, or asphalt lines where they’ve filled in the cracks, it makes noise where you hear it in every one I drive over.
This actually drives me crazy to the point where I don’t like driving it and want to get rid of it…especially with the kind of money I’ve put into it.
