kobra
- Joined
- Oct 25, 2020
Hi all,
Out of respect for @UglyViking and keeping his thread clean, I'm starting a new one regarding 3/4 ton trucks and GVWR.
Caveat, no "weight police" intended here, just trying to provide information for those who may not know.
The first thing I see is that there is a lot of misunderstanding about the 2500 class and payloads...
- There are many debates about the 10k GVWR is artificially low and how the trucks are capable of much more. Related, many note that 2500s are often built similar to the 3500 class in axles, tires, etc. All true.
- With the latest crop of diesel 2500 class diesel trucks, the manufacturers payload rating can be less than 2000lbs.
- There are just as many debates about how to "increase the payload" of a 2500. Usually this is in defense of adding something like airbags then exceeding manufacturer payload, GAWR or GVWR.
... But the reality is that only the manufacturer (or in some cases a certified aftermarket shop) can increase the payload rating of the truck. So, for example, if you add airbags, you can load the truck above the GVWR, and the truck will not sag as much and will handle better. Maybe you don't care, and honestly within reason, I don't care either. Just don't pretend you've somehow increased your payload rating as you haven't.
The second thing I see is the debate on why manufacturers seem stuck on the 10,000lb limits for 2500 class. This has to do with truck classes setup by the DOT (technically a sub division for highways). So this is at the federal level in the US and adopted by many provinces, including the one where I live. The 10,000lb limit is the top of the class 2 category, specifically class 2b. Once a truck is 10,001lbs it is now a class 3 truck. Some of the new GM 2500s have exceeded 10k in GVWR; so they are now a class 3 truck by regulation.
If you want to wade through the DOT site for the info, go for it. Or see here, pretty good summary - https://en.wikipedia.org/wiki/Truck_classification
Why might the truck class matter to you, or not? In some cases, the class 3 is enough to change registration and insurance costs. Where we live, it matters very little but apparently in other areas it can be a lot more. Call the regulations antiquated, or silly, or whatever, cause I agree and think they are. Just realize the regulations exist.
There are those who have bought a 2500 thinking that all they need to look at is the "tow ratings". They are then surprised to find out they are exceeding some of the legal limits of their trucks. So, I hope this information will help others decide if a 2500 fits their needs, or if a larger truck is needed.
B
PS. For the record, I've had several 2500's and I've worked them hard with trailers, goosenecks, 5th wheels, etc; on and off the farm, and as part of a couple of trucking businesses. My last truck was a RAM 2500 and it might have been overloaded at times. I bought them because they ride better. But then I've bought 3500s when I know I need to tow heavier (12k+), and duallies for larger loads (20k+). Right tool for the job.
PPS. speaking of right tool for the job, this is what I used to drive... I'm out of that game now, so this is my nephews truck. And, this is towing a "light load"; loaded up with boosters and jeeps it has 46 tires on the road...
B
