21 3500 level kit
19 2500 limited
Sep 19, 2020
Just traded in my 19 2500 limited for a 21 ho 3500 longhorn limited srw.
The 21 had dealer installed 35/12.50 20 nitto ridge grapplers installed and a 2.5" level kit.
Trucks sets level.
With a leaf spring truck is it going to sag once a trailer is hooked up?
Assuming the level kit is to clear the larger tires?
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Level kit is mostly for aesthetics, IMHO. This is also a very subjective subject
I had no problem fitting 35s on my truck without a level kit. I like a little rake so I did a 1” front lift kit so I still have ~1” rake.
Truck squat depends heavily on tongue weight but I would wager you will be nose high.
if it were me I would decide if I liked the slightly lifted look or stock look or something in between.
3 options as i see it.. 1) Either return to stock, or 2) drop the front to a little less lift or 3) shop for a 1-1.5” block kit for the rear.
slvrsix7
Jun 16, 2021
I leveled my 21 3500 with 1" coils and with my 14k fifth wheel the rear drops 2", which makes the rear an inch lower. Planning on doing bags.
