Texasram1
- Joined
- Jan 11, 2022
I know. But i’d rather do it myself if I can.They should adjust that under warranty
Mine is like that, has been from day 1, no leaks thus far... Knocking on wood currently.Can anyone confirm if the rear sunroof seal should be flush, or protruding like mine is?
Ive heard horror stories of leaking sunroofs, so I’m a bit concerned...
thanks for sharing.Mine is like that, has been from day 1, no leaks thus far... Knocking on wood currently.
Well if you get it adjusted or figure out how to diy I'd appreciate an update... Sounds like I might need to address it.thanks for sharing.
After looking at mine more closely after my post yesterday, i can see that it barely seals. And I mean barely. It def needs an adjustment down.
Good luck. Pls let us know where they say its coming from.I’m bringing my 22 3500 Drw Laramie in for a leak. Not sure if it’s the sunroof of the overhead cab lights. I have a drip when my truck is sitting that drips from the grab handle on the drivers side.
Have you checked the drain tubes in the a-pillars to ensure they are not clogged with anything?MIne is leaking out of the driver-side noise cancellation microphones. Dealer says it needs a new glass, as the seal is shot (evidently, they are one unit) and wouldn’t you know it, it is not covered under the MVP that I paid over 3 grand for…and, it was 24 hours after my 3/36 expired…only 18K on the truck…beyond frustrated. I actually wrote @RamCares before my 3/36 because it was the weekend and the dealer service was closed. Super annoyed, also thuds a little when I open and close it. I tried adjusting the rear height a little w/the T20 screw driver as the driver side corner was well below the 1mm roof line. I will attach a video and pics. Oh, so the sunroof glass is over 600 and so is labor! It “thuds” a little when I open and close it too, so I don’t know what is going on. I cannot attach a video for some reason.
Hey there,MIne is leaking out of the driver-side noise cancellation microphones. Dealer says it needs a new glass, as the seal is shot (evidently, they are one unit) and wouldn’t you know it, it is not covered under the MVP that I paid over 3 grand for…and, it was 24 hours after my 3/36 expired…only 18K on the truck…beyond frustrated. I actually wrote @RamCares before my 3/36 because it was the weekend and the dealer service was closed. Super annoyed, also thuds a little when I open and close it. I tried adjusting the rear height a little w/the T20 screw driver as the driver side corner was well below the 1mm roof line. I will attach a video and pics. Oh, so the sunroof glass is over 600 and so is labor! It “thuds” a little when I open and close it too, so I don’t know what is going on. I cannot attach a video for some reason.
