Once you choose inspect, click on Network and then refresh the page. Then scroll down the until you see your name and click on that. It should have a little bit more info in that section. It shows dealer details, order status and VIN details, you can also click the triangle next to each to see more info.What’s the trick again, inside the tracker to see more info? I found inside info using the Inspect but then what do I do again?
Thanks,
Dave…
Thanks but I couldn’t find current location. That’s what’s I was hoping to find. ETA is currently 7/8 and my last update from dealer was its in Kansas.Once you choose inspect, click on Network and then refresh the page. Then scroll down the until you see your name and click on that. It should have a little bit more info in that section. It shows dealer details, order status and VIN details, you can also click the triangle next to each to see more info.
Congrats man!My salesman is clueless and don't know s%$# when I called but today the tracker updated to shipped. It's been a long journey but it's almost here...I think.
Mine is going to California. Salesman said he thinks maybe two weeks for it to arrive.Congratulations. That's awesome news. Where's the truck going. I'm in Pennsylvania and ordered a loaded Laramie. I ordered mine on the same date as you. The truck was built on May 31st.
Is it even possible to build a highly optioned Mega Cab Laramie in 1 day ? A few days shy of 4 months since I placed my order to my surprise my truck was in production June 13th and a even bigger surprise truck is built on June 14th.
I drilled down on my tracker info and under section 2 it says arrival date of 6-26-22? I don't know if that is accurate? The actual tracker shows both shipped and delivered as TBD.
I did the same thing on my tracker and I saw an arrival date of 7-19-22. I've seen this date before but I can't recall if it was a delivery date or a ship date. Currently both are TBD.
Mine has the same thing. Once my truck was in production (E) on 23 May it showed an arrival date of 2 July. Once it was built (KZ) on 27 May that arrival date turned back to tbd. The 2 July still shows up under 'inspect' under E. It's probably a guesstimate of about 6 weeks? I'd say it means nothing.I drilled down on my tracker info and under section 2 it says arrival date of 6-26-22? I don't know if that is accurate? The actual tracker shows both shipped and delivered as TBD.
I just read your response and tried looking into the Ram tracker and could not find a way to " inspect"Once you choose inspect, click on Network and then refresh the page. Then scroll down the until you see your name and click on that. It should have a little bit more info in that section. It shows dealer details, order status and VIN details, you can also click the triangle next to each to see more info.
Any help would be appreciated,
thanks in advance
Leroy
thank you brother ram member
- Open the ram tracker page
- Right click on the page
- Select inspect at the bottom
- On the page that opens, select network near top
- Refresh the page (or hit F5)
- Under the name column, find your name and left click it
- In the right column you should now see your info
- Click the triangle next to each item to expand the information that is underneath
Must have had to try it out. Lol. We have crappy roads in Iowa...and a lot of rain lately.I wonder what they did for the QC Test Drive. There's some muck up under there.. Not
