Man I like the limited night edition rims a lot!Limited (Night Edition selected)
(Night Edition are unique compared to prior years)
View attachment 23557View attachment 23558
Longhorn
Laramie (Night Edition may not be available for order right now)
View attachment 23567View attachment 23573
Bighorn
View attachment 23563 View attachment 23564
Tradesman
View attachment 23565View attachment 23566
Thats dumb. The limited night edition 5 spoke you posted is what was on my 2019 Bighorn 1500. I highly doubt it is on a 3500. Ram probably messed up
This is a 3500 Limited night edition someone got the other day... https://hdrams.com/forum/index.php?...r-here-new-users-read-post-1.5385/post-122491
Go figure Rams site is wrongYou're right. They had been the same as the shiny wheel, just black.
The site is showing the wrong wheel. I just looked at it again and it's only 6-lugs. ROFL.
Wheels are 45 pounds each tires 50Anyone have an idea what the 18x8 steel chrome clad wheels with Transforce A/T’s weigh each? Thanks!
" title="" style="cursor: pointer;">Tire | Rim |
| " data-original-title="" data-placement="bottom" title="Wheel Calculator" class="_popover" style="cursor: pointer;"> | |
275/70R18 118T | 8Jx18 ET20 | 3.4 / 4.8 | ||
285/60R20 115H | 8Jx20 ET55 | 3.5 / 4.9 | ||
305/45R22 112V | 9Jx22 ET45 | 3.8 / 5.2 |
Ram 3500 2022 6.7 TD
– Generation: DS/DJ Facelift [2019 .. 2023] " data-original-title="Pickup Regular Cab, 2d" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29); text-decoration: none;"> " data-original-title="Pickup Crew Cab" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29); text-decoration: none;"> " data-original-title="Pickup Mega Cab" data-trigger="click" data-placement="bottom" data-html="true" style="color: rgb(190, 62, 29); text-decoration: none;">
– Power: 420 hp | 313 kW | 426 PS
– Engine: 6.7L, I6, Diesel
– Options: Lone Star, Big Horn, Tradesman, Laramie, Limited, Limited Longhorn
– Center Bore: 121.3 mm
– PCD: 8x165.1 (8x6.5)
– Wheel Fasteners: Lug nuts
– Wheel Tightening Torque: 190 Nm
– Thread Size: M14 x 1.5
– Trim Production: [2021 .. 2022]
" title="" style="cursor: pointer;">Tire Rim " data-original-title="" data-placement="bottom" title="Wheel Calculator" class="_popover" style="cursor: pointer;"> 275/70R18 118T 8Jx18 ET20 3.4 / 4.8 285/60R20 115H 8Jx20 ET55 3.5 / 4.9 305/45R22 112V 9Jx22 ET45 3.8 / 5.2
Interesting to note the difference in offsets in the 2500 vs 3500 wheels, minor variance for the most part except for the 18" wheels, almost an inch difference in offset. Something to keep in mind if buying take-offs.
Ah! I thought it might have made sense due to bigger brake components or something. Appreciate the info.I suspect there is an error on that website as Ram publishes the same part numbers for both 2500 and 3500.
