Thanks for the info. Do I have to worry about offset or can I just go with 20" wheels?YES A 245-60R-20 is almost identical to the stock 17"
I'm pretty sure the 17 inch wheels on my 2020 RAM dually truck are all the same.yes there are a ton of aftermarket options. I am running 20x8.3 fuel wheels with 35x12.5x20 mud tires on stock suspension 2020 3500 drw with no rubbing at all. I believe the front wheels are something like +105 offset.
The oem 17's are 17x6" and the fronts and rear outers will be the same specs just flipped in the rear, if you have the polished aluminum wheels only the outer face is polished, so if you flipped and installed the fronts on the rear it wouldn't look good. But possible. The rear inners are black steel. The spare can be run in any position. Aftermarket 20" wheels are not made to be rotated. The fronts are front specific and the rear outers only work as rear outers. If you want to rotate you can only swap side to side in the same position or have the tires pulled from the rims and rotated. This is the case for fuel aftermarket dually wheels, there may be other brands that differ.I'm pretty sure the 17 inch wheels on my 2020 RAM dually truck are all the same.
My 2020 RAM 3500 Tradesman dually has the steel wheels with the chrome look covers front and rear. Tradesman dually wheel can be rotated and just swap the chrome covers.The oem 17's are 17x6" and the fronts and rear outers will be the same specs just flipped in the rear, if you have the polished aluminum wheels only the outer face is polished, so if you flipped and installed the fronts on the rear it wouldn't look good. But possible. The rear inners are black steel. The spare can be run in any position. Aftermarket 20" wheels are not made to be rotated. The fronts are front specific and the rear outers only work as rear outers. If you want to rotate you can only swap side to side in the same position or have the tires pulled from the rims and rotated. This is the case for fuel aftermarket dually wheels, there may be other brands that differ.
What are the tire and rim specs? Size, offset, bolt pattern front and rear? I’m looking to do something similar with the carli 3 1/4 lift and 37s but I would like more of the deep lip look on the frontsJust finished installing 20s on my new dually. I also put a Carli 2.5 leveling kit as I wanted larger tires. Little bit of trimming up front so no rubbing. Just got done doing everything late Sunday but here’s a night shot of my Laramie night edition with 80 miles on it.
I will do that! I actually plan on getting a big toy hauler as well. Your truck looks awesome! Thanks for replying!I don’t want to say the wrong sizes so what I’d do if I were you is get in contact with someone at custom offsets and they’ll set you up how you want. Kinda wish I would of went a little more of a lift, but I do plan on towing a large toy hauler in the near future and was concerned about going higher. Tires are Cooper STT pro 37/12.50/20”
