Metternacht
- Joined
- Jan 15, 2021
Love the last shot! Can you share how you captured that? Thanks.
$69Ordered Colorado ZR2 Bison light bar brackets from AEV Conversions although it looks like they may work for me. Hopefully next week I am finally able to mount my Diode Dynamics Stage Series 30" white combo light bar on the nose of my adventure vehicle.
Note how the upper surface of the bumper rolls forward and slightly down - most normal brackets are designed for a flat surface. My AEV Premium Front Bumper shares a similar profile. Also, I want the light bar to be projected forward an inch or two so it does not interfere with operation of the clutch on the Warn 16.5ti heavyweight winch.
Copy of receipt for reference.
This afternoon was spent opening up the hole for the diesel filling door to its final dimension. A die grinder with a carbide bur and manual deburring tool was used and time was taken to slowly open the up to the final dimension. Several coats of protective paint was applied to all holes and the dimension matched the cap perfectly.
Here is the final installation of the cap. Loctite 222MS (purple) was applied to all fasteners before being torqued to 45 pound-inches.
There she is - my beautiful diesel filling cap on my AEV Prospector with a 6.4 liter Hemi engine. I also finished up routing the hoses underneath and was very happy with how everything turned out. They are very clean and orderly with none being under tension.
Here is a piece of my interior from my Four Wheel Camper - it is a small rectangular piece of wood that mounts to the outside of the battery box in the rear. I though this would be a perfect place to mount the Victron Energy BMV-712 Smart head unit. This component was salvaged from one of my previous adventure vehicles. Here is the door in a machinist's vise with a level to verify the work was in the proper plane prior to cutting. These small details save time and money over the long term and directly impacts work quality in a positive way.
Again, taking time and having the proper tools is the correct way to do things every single time. I am not going to become philosophical here but now is the time for American men to "get up, dust off, reload, re-calibrate, re-engage, and go out on the attack." The future of humanity depends on you doing the best you possibly can.
Here is the attachment sleeve passing through the back of the interior piece. I still must install the shunt along with a few other cables but that is just busy work that I will accomplish someday soon. The BMV-712 is a really nice unit which provides a wealth of information. Once the system is up and running I will post additional photographs and associated information.
Have you decided on what Ditch lights you will be using?
Much of this weekend was spent installing my AEV Snorkel, OEM projector LED headlights, and custom harness built by Jimmy07. Here is my good buddy Ed using a Starrett automatic center punch to reference where we will be drilling pilot holes on the template supplied by AEV.
As expected, we progressively worked up from 1/8" pilot holes to two 1/2" and nine 1" holes. We spent nearly an hour moving the paper slightly, checking, etc. All the holes were placed perfectly.
The blue strips of tape were used to cover the 1/2" holes to we did not mistakenly drill one out to 1" - that would have been catastrophic. When you are deep into a job and so close to the work a seemingly small mistake can create an unrecoverable error. Taking a few minutes to reference the template and placing tape over the holes you do not want to drill is a simple and effective solution. Probably the most challenging part of working on the fender was balancing pressure and rotational speed while the fender wanted to flex.
Here is Ed cutting lines between the finish holes.
Has anyone had their battery go bad after only three years and 50k miles? On Saturday when we finished work I attempted to start my truck and the battery was dead. We jumped it and I was able to move it and let it idle for a bit pushing 14.0-14.1 Vdc. Sunday morning we tried to start her again and it was no joy. Since we were going to grab breakfast I figured I would let my Renogy Solar Suitcase try to charge the main battery and see if I was able to get her started. Surprisingly, it worked!
Drilling holes in the a-pillar where two 1/2" rubber expansion well nuts will be used to hold the upper section of the snorkel body in place. The instructions called for 1/2" holes and although we progressively worked up, our finish hole was 31/64", or approximately 0.016" under. We placed some black RTV on the rubber expansion plugs and they fit very snugly into the holes.
The AEV snorkel installation is not for the faint-of-heart. My recommendation is that if you are having an AEV Prospector built, pay the additional $420 and have the snorkel installed by AEV. Unfortunately, when my truck was manufactured in mid-2021, the snorkel was still many months away from being produced. Some of the most challenging parts of the installation centered around the removal of the trim piece under the front grill without disconnecting the front bumper and the installation of the new AEV airbox which is a combination of metal and plastic. Overall, it is a pretty impressive kit for the money although there is always room for improvement. Was it perfect, no. But for the money I consider it a great value.
