I am referring to the retention hook on the fairlead. It Appears to be modular. some older pictures show them on both sides and on the 2021 PW it is on the drivers side.The hook is just connected to the thimble with just a pin with a cotter pin .
or are you asking about the hook retention tab(s) on the fairlead itself? I think it’s cast in to the fairlead
Ram 2500 Bracket winch, picture shows incorrect - 68378860AD | Myrtle Beach SC
Bracket winch, picture shows incorrect. Picture shown incorrect from moparcall for more details. Ram 2500. Genuine Ram Part - 68378860AD (68378860AB, 68378860AC). Ships from Myrtle Beach SCwww.moparpartsinc.com
I am going to remove it and see if the retention hook is modular, after I find out the torque specs to put it back on. I will post my findings. Thanks.Other people have removed it and said that the bolt is very, very tight. A good breaker bar was necessary.
They changed it mid 2019. The early build ones have the tabs on both sides, but my late build 2019 only has one.I am referring to the retention hook on the fairlead. It Appears to be modular. some older pictures show them on both sides and on the 2021 PW it is on the drivers side.
You are 100% correct. it is not modular. Here is a picture from the back. Looks like I will be getting a new one. Message me if anyone wants the stock fairlead. Thanks.They changed it mid 2019. The early build ones have the tabs on both sides, but my late build 2019 only has one.
I’m 99% certain it’s cast into the fairlead not modular.
Not really an issue as long as the fairlead rollers don’t have a ton on play. It is important however to not use a roller fairlead that was previously used on a steel wire as it may have burrs.Agree the OEM hawse appears to be rough. I have not used it yet but it looks like it would be hard on the synthetic rope.
I am not an expert, but, I don’t think a synthetic rope can be used with a roller fairlead. Something to do with the rope getting caught in the corners during a side pull.
I don’t think it’s better. I know it’s better.Explain why you think hawse is better, please
