QCHunter
- Joined
- Feb 8, 2021
Perfect. That’s what I was looking for. I kept looking at the cheaper caps that weren’t made for the fins inside the filler neck. I will order this to help keep dust and water out.This is the one I got from Amazon.
I turns only a little bit "lock"/tighten into place.
Here it is installed.
I would have ordered a cap from Geno's, but it was listed as backordered when I got this one.
I just got the same amazon cap had ordered from genos and they told me both locking and non locking would be 45 days for stock to arrive so I cancelled my order.This is the one I got from Amazon.
It turns only a little bit to "lock"/tighten into place.
Can you post a picture of the cap upside down so we can see the part that fits inside... Does it have groves that match the inside of the fill hole? The one I got from amazon doesn't fit quite right with the "fins'This is the one I got from Amazon.
Here are a few angles. The cap seems to push the filler neck flap open slightly, but as you can see there is an o-ring on the cap itself.Can you post a picture of the cap upside down so we can see the part that fits inside... Does it have groves that match the inside of the fill hole? The one I got from amazon doesn't fit quite right with the "fins'
