Thank you - the red tab is flush with the edge of the connecter so I could not figure how to pull it out. If I do not disconnect it all the better - it appears to be connected to the coupling hose.Pull the red tab back and press the release tab to unplug it. But you don't need to disconnect it as the CCV sensor is in the valve cover not the CCV itself
You need a pick tool to make it easy its not ram doing anything different than any manufacture.The pressure sensor is connected to breather hose coupler and for the life of me I cannot figure out how to get the red tab out. There is a small hole on the opposite side of the locking clip that I have not tried to insert a wire into. I wish RAM would stop trying to prevent us from working on the vehicles.
I will send a photo tomorrow. I just finished in the rain and hail. I was able to remove the breather hose and 3 wire retaining clips which gave me enough room to move the cover out of the way so that I could replace the CCV filter. All went well until I dropped the oil filler cap and it fell behind the fan housing -- there is no way to get my hands in there so remove two plastic retainers and a bolt, etc.Im curious could you post a picture because my CCV sensor is bolted to the valve cover behind the filter not on the tube see image posted. I dont need to disconnect my wiring to change the filter from what i can remember i may have to go look but i do not remember seeing it
I just checked i do have it on this truck i must have been thinking about my older 6.7, why they have 2 sensors for CC pressure is just silly to meI will send a photo tomorrow. I just finished in the rain and hail. I was able to remove the breather hose and 3 wire retaining clips which gave me enough room to move the cover out of the way so that I could replace the CCV filter. All went well until I dropped the oil filler cap and it fell behind the fan housing -- there is no way to get my hands in there so remove two plastic retainers and a bolt, etc.
