2021 CTD oil grade
Rockwell
Sep 19, 2021
Hello, I have had two previous CTD’s 13/16, has the factory recommended oil grade remained the same or has it changed with the new version of the 6.7?
Dwilly
Apr 19, 2020
Cold weather 5w40
Hot weather 10w40.
Grayson
Jun 7, 2021
I'm glad that bulletin was posted I had no idea it changed. Wonder if they have a disclaimer on the Valvoline jugs yet? Have they stopped recommending Power Kleen fuel additives as well?
Dwilly
Apr 19, 2020
Yup
cummins has only ever approved power service additives
Rockwell
Sep 19, 2021
I just sold my 2016 with 28k kms. The new truck with a 24k interval would equate to one oil change in 5 years!
I’ll stick to my 4K oil change regiment
flan
Aug 16, 2019
I only do a oil change once a year due to having a VW TDI I mostly drive when not needing the truck for towing the TT, so I use 5/40 year round.
They do say 24,000km or 1year on the oil right in the owners manual sooooooooooooo
I only put on about 5K/year so do them yearly as prescribed, in the spring just before towing season.
Project Farm did an episode on his 2nd gen(?) and a tractor that debunked the need based on oil analysis and while I value his reviews, I'm sticking to the OEM recommendation.
Ram911
Sep 25, 2021
Can the 2021 6.7 use API-FA4?
Took this from the shell site
"Shell ROTELLA® T5 Ultra 10W-30 is suitable for use in 2017 as well as some late model engines allowing an API FA-4 diesel oil in this viscosity. Some engine manufacturers do not yet approve the use of API FA-4 engine oils, while some allow limited backwards compatibility to earlier model year engines. Check with your original equipment manufacturer regarding the use of API FA-4 diesel oil."
LINK
The NON-Ultra seems like the right choice.
AFAIK, Cummins has not approved the use of FA-4 oils in any B series engines.
