2020 RAM 3500 check engine light, codes P1E1C and U040F. Any tips on what to look at first?
LBC_Jeff
Apr 4, 2023
Hi everyone. I have a 2020 RAM 3500 Laramie with a 6.7 diesel. the check engine light came on a few days ago and when I check the codes it came up with those two. I cleared the codes and they came back. Have any of you had these codes and if so, how did you resolve?
in looking at google searches it looks like it could be the DEF dosing control unit or wiring that goes to it, maybe? Any idea where the DEF dosing control unit is and how to test it to see if it's the issue?
thanks,
jeff in long beach.
from google searches:
Code: P1E1C
Definition: Reductant System Wake Up Circuit High
Description: The Diesel Exhaust Fluid (DEF) Dosing Control Unit is used to control the operation and monitoring of the Diesel Exhaust Fluid system. The DEF Dosing Control Unit is the central control for the aftertreatment diesel exhaust fluid dosing system, and handles the tank level sensing, tank temperature sensing, line heating, and tank heating. The DEF Dosing Control Unit shares information with the Powertrain Control Module (PCM) over the J1939 Data Link. The PCM will illuminate the MIL light after the diagnostics runs and fails for two consecutive trips. The PCM will turn off the MIL light when the monitor runs and passes in three consecutive key cycles.
Cause:
  • DCU WAKE UP SIGNAL SHORTED TO VOLTAGE
  • DCU WAKE UP SIGNAL OPEN/HIGH RESISTANCE
  • DEF DOSING CONTROL UNIT
Code: U040F
Definition: Invalid Data Received From Reductant Control Module
Cause:
  • DEF DOSING CONTROL UNIT CONNECTOR CORROSION OR FOREIGN MATERIAL
  • INCORRECT J1939 DATALINK TERMINATION RESISTANCE
  • POWERTRAIN CONTROL MODULE (PCM)
PRS
Feb 23, 2019
Arvada, Co.
The dosing control unit is mounted on top of the DEF tank. It has two wire harnesses going to it. The DCU wake-up circuit is on pin 4 of the smaller connector. You could separate the connector, inspect for pushed back or dirty pins, check for battery voltage on the pin. If you see no issues and you have voltage you could clear the code and try again, or if you have no way to clear the code it takes three drive cycles to clear if all is ok again.
Sometimes simply disconnecting and reconnecting the plug will clear the bad connection and it will work again. If that's the case, get some contact cleaner and thoroughly clean the connection.
LBC_Jeff
Apr 4, 2023
thanks for the info!! I'll try that when it stops raining!
jeff in long beach.
JimKIII
Jul 29, 2021
@PRS's explanation is why I keep coming to the hdrams forums. His knowledge and willingness to share it is invaluable.
