My 2018 Power Wagon with factory LED tail lights and halogen projectors is having some issues.
Problems:
#1. For the rear tail lights, only the passenger side is not working. The only thing that works is the reverse light. I do occasionally get a warning on the DIC that the Rear Tail Light isn't working. But the light is always out regardless.
#2. For the head lights, only the driver side projector light is not working. High beams work, running lamp works, and turn signal works
Things I've Checked:
#1. Checked fuses
#2. Checked 3rd Brake light. All LEDs, flood lights, camera work
#3. Pulled battery
#4. Replaced tail lights and same issue persists
#5. Replacement headlights already on the way
I am starting to run out of ideas. I had read enough to know the LEDs go bad in the tail light that I just assumed it needed to be replaced.
Problems:
#1. Checked fuses
#3. Pulled battery
