Is anyone running Black Rhino Arsenal rims with stock tire sizes (275/70/18)? Not certain these will
fill without some kind of
spacer. These are some beefy wheels. Not a fan of the black spoke-type aftermarket wheels and these look good to me.
No bueno on stock (275/70/18) tires. Wheel is 9.5" stock tires will fit a 7"-8.5" wheel.
A. So if you want to use this wheel, you can't use stock size tires.
B. If you want to use this wheel with tires
up to 35s or close equivalent at 11.5ish wide, as
@BikePilot mentioned, yes go for it, +12, no spacer needed.
Sorry for answering both ways but your (fill) made me wonder if you meant will the bead seat (no)
I also went with 18" Arsenals but with the -18 offset and 34.8"x11.3"x18" tires (285/75/18 Falkens)
Edit to add: the 295/65/18 shown in recommended tire size photo above is 33.1"x11.8"x18 in a Goodyear Wrangler Duratrac
