1-1.5 LEVELING KIT
Mar 17, 2021
Looking for a small 1-1.5'' leveling kit for my 21 3500, would like to keep factory ride. I'm liking the proryde lift as of now. Would i need sway bar extension and trak bar as well.
loveracing1988
Feb 16, 2021
I had the traxada on my previous truck and it was nice. I had a set of bilstein 5100's on it too so didn't even consider shock extensions. If you are looking for slightly higher quality thuren does have lifts as small as .5".
dslbrnr
Nov 27, 2020
SO Utah
I've been eyeing the Thuren softride .5" front springs and Fox shocks F&R. I plan on mounting 285X75's on my stock wheels and be done with it
slvrsix7
Jun 16, 2021
I did 1" Thuren coils in the front along with their track bar and Fox shocks. Without a track bar your axle will shift slightly to one side, but with only going .5-1" it would be barely noticeable if at all. Sway bar extensions will not be necessary.
Razzman
Jan 10, 2021
Thuren 1" coils, Thuren sway bar and Fox shocks. Rides so much better and worth every penny. Thuren told me not to worry about the track bar now with that amount of lift.
loveracing1988
Feb 16, 2021
I still have the OEM track bar with a 2.75" level and it still didn't shift it that far. I will be installing the thuren track bar at some point whenever I fall into a money pit.
dslbrnr
Nov 27, 2020
SO Utah
Hows the ride compared to stock. Would you mind posting a few pics
Mar 17, 2021
I installed the Traxda 1'' kit this weekend, took about 30 minutes. It was perfect for what I was looking for. Only complaint is traxda's powercoat is crap but for under $100 you get what you get.
wpgram
Jul 9, 2020
Winnipeg, Manitoba
Which springs did you use? i only see the .5" and 1.75" for the 3500 6.7
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
Dude you’re a beast. It takes me 30 minutes and 1.5 beers to put the truck on jack stands and get the tires off of it
slvrsix7
Jun 16, 2021
I had a 2018 Ram 2500 and moved the coils over when I traded it for the 2021 Ram 3500. I checked with Thuren and they said they'd fit no problem. If you look up the 2500 springs there is a 1" option. Looks like the difference is you gain more lift than 1" because the stock 3500 sits a tad higher. Come to think of it now it did seem like the coils lifted my 3500 higher than my 2500, but I chalked it up to it being a 2021 vs 2018. Never took measurements so can't say for sure.
Razzman
Jan 10, 2021
It's weird, I added the 1" coils in my 2500 and got 1 1/2" of lift. Some said it will settle but 5K later it's still the same.
lgarrison34
Jun 29, 2020
Do have to add aftermarket shocks with the 1" coils if you have the off road package? Also, Thuren only sells the 1" for the diesel. Will it not work with the Hemi for some reason?
loveracing1988
Feb 16, 2021
Yes, the shocks need to be valved for the springs. If you don't want to spend the money get the overland shocks.
wpgram
Jul 9, 2020
Winnipeg, Manitoba
How level do you sit now?
I wonder if the 2500 1" is the same as the 3500 1.75" because of the 3500 being abit higher?
