I just had my 3.25 commuter installed on my 2023 3500 Dually w/Aisin (Crew/4wd).
Went with a 2” block in the back in lieu of the progressive add a pack (can’t do it with the Dually they said) or the full leaf. 2” should have leveled the truck.
After taking the before/after measurements I only got 2 1/4- 2 1/2” of lift out of the coils. Not sure why. I know it should have been at the 3” end of the 3-3.25” they quote due to the moment arm and weight of the front end, but not 2 1/4”.
The truck has almost a stock rake to it after the install. The kit was confirmed and spec’d by CJC. It got finished up Friday night late so couldn’t contact CJC.
I’m also getting a pretty significant vibration over 50mph. I dropped it off at the installer early this morning for troubleshooting. It’s on 37s. Hopefully it’s a tire, however they were just balanced by a shop.
Something is different about the suspension on these 2023 Duallys. I think it has to do with the rear. My pre install rake was almost 4”. I know for a fact the 2021-2022 that wasn’t the case. Regular block and u bolt kits for a 5g don’t fit so something is new and different.
It will be interesting to see what they say at CJC. Seems the crew cab short beds have had no issues at all. I’m really hoping this isn’t a driveline vibration. I keep reading that other lift manufacturers say you can’t go higher than a 3” because you can’t index or reclock or drop the transmission on a Aisin Dually. Given basically only got a 2.25” level out of the front end coils I should not be having any issues. Hoping one of the tires is out of balance.
I’m going to have them ensure by the spring part # that they are the correct springs.
I didn’t take a picture of the overall rake but this is the front end. There’s the before and after photos in same location for comparison. Tire is exactly 5” taller. You can see compared to other 37” installs, it’s about an inch short.
Keep you all posted and if anyone has any ideas on the unexpected results of this install please share. In the meantime I’ll let my installer who is awesome dig into it.
