My first post is about what I “purchased” and why.
The following list is what you will need for the HD Ram upgrade:
The AlfaOBD software only works with Windows and Android (it does not work with Apple). I used OBDLink EX (USB) with my Windows laptop. If you use Android, you may want to use OBDLink MX (Bluetooth). There are several ways to bypass the Security Module, some need to be plugged into the back of the Security Module (difficult to get to) and some plug into the CAN Bus and OBD connector (much easier to get to). I chose the CAN Bus / OBD connector method. I have not made the software changes yet so I will leave that procedure up to those with more experience.
The CAN Bus jumper plugs into the CAN Bus behind the light switch and the Chassis_Left connector which is located behind the right wheel. The Mirror Jumores are plugged into the Door Module behind the door panel and are threaded up to the mirror glass.
To the best of my knowledge, this list is correct although a confirmation and or correction by Jimmy07 would be greatly appreciated.
| Right Tail Light Assembly: | 6844 6838 AE |
| Left Tail Light Assembly: | 6844 6839 AE |
| Tail Light Jumpers (2 required): | 6839 6013 AB |
| Right Mirror Glass: | 6840 1394 AA |
| Left Mirror Glass: | 6840 1395 AA |
| The spaces in the Mopar part numbers are for readability only! |
| CAN Bus Jumper: | Contact: Jimmy07 |
| Mirror Jumpers (2 required): | Contact: Jimmy07 |
| AlfaOBD Software: | Paddle.com |
| OBDLink EX or MX: | Amazon.com |
| Security Gateway Bypass: | kaotech.com |
