dave41079
I have a solution for that. You just need a new camera (around $100 for the same one that's in the CHMSL), and some fakra z extension cables. You can either connect directly to the mirror, or connect where the current camera wire is behind the CHMSL.This is awesome... I'm hoping maybe once this is released that there will be a retrofit that will work on the 2021's. I'm trying to figure out a way right now to re-locate the rearview camera input so that I can install a camera on the back of my camper shell, and have it display continuously on my mirror the way my CHMSL does now.
I actually intend to run two wires down from the CHMSL and one from the camera at the back of the truck all to end under the rear seat. I can then connect either the new camera or the existing one depending on whether my Softopper is on/up or not.
