MEZZ2006
I just got my Mopar mudflaps installed yesterday. They are heavy duty. I was able to do all 4 without removing the wheels and with a standard pop rivet tool. The rears have the little plastic "apron", I was able to remove that very easily with a needle nose pliers as it is only attached with 3 push pins. The fronts I was able to do by turning the wheels. Not having the plastic rivet tool was the toughest part. My rivet tool was not supposed to work with the size of the plastic rivets, but I was able to wedge it in, but then I had to come up with spacers between the nose of the rivet tool and the rivets to give a surface to pull on the rivet with. It worked, but not having access to the tool or anywhere to get one, other than online, I made due.
