Tschneid62
I noticed that too with the Ram box you can not order the factory puck system, but you were able to install it with no issues? I was wondering why its not available with the Ram box. Do you like your set up(Ram box)? Iwas considering it but I wanted the factory puck system. It sure looks like the Ram box would be handy for camping.I installed both the B&W turnover ball and the OEM puck system in my 2019 Ram 3500. I have the Ramboxs so it wasn't a option for the truck. It took about 2 hours start to finish. You have remove your spear tire and tire heat shield. You also have loosen your truck bed bolts jack/lift it up to put the puck between the bed and frame. As for cutting the holes, the one for the ball was simple. The for the puck system were not that bad. Even if you are off some the hole covers hide that
