Truck came with 18" firestones it was fine. Installed 20" with 295/65r20 toyo open country and now it bounces over bumps steering wheel moves. I'm looking at a carli stabilizer. Does anybody have experience with a better stabilizer correcting this.
That seems to reinforce the thought that it is width/offset relatedThat's interesting.
I have a 2019 Tradesman that came equipped with the 18" transforce on junkyard wheels and replaced them Nitto 285/65-20 EXO Grapplers on 20" Longhorn wheels.
I have never experienced what you have.
Ok so you are running basically same setup. If I hit a bump I need to correct my direction. In my 550 I can hit anything barely holding the wheel and it stays where it was. Maybe this state just needs to fix the speed bump crater roads.That's interesting.
Do you live in Dutchess or Putnam county?Ok so you are running basically same setup. If I hit a bump I need to correct my direction. In my 550 I can hit anything barely holding the wheel and it stays where it was. Maybe this state just needs to fix the speed bump crater roads.
Not for your average pot hole or frost heave. I will be honest when I see something like that I do just about anything to avoid them.Offset is close to same. The rims are 20" ram rims off a limited 2020. New take offs. I took off steel 18" mines a 2020. No rubbing at all. Not even close. Let me ask this. Can you lay your wrist over the top of your steering wheel and hit a good bump without having to correct the truck when it's over. In my 550 I can the ram I need to be ready to correct it. Not the end of the world but it's not right either.
Dutchess and work in Putnam.Do you live in Dutchess or Putnam county?
I noticed your license plate frame.Dutchess and work in Putnam.
New York...When taking the highway means you are going OFFROAD!I noticed your license plate frame.
Route 9D?New York...When taking the highway means you are going OFFROAD!
