I gotta know.. How did you see your front license plate while at high speed?After removing the air dam I had to fabricate a bracket that attaches to the bottom of bumper and then bottom screws of the license plate bracket. Otherwise the bracket will wobble at high speed like crazy
Front grill cameraI gotta know.. How did you see your front license plate while at high speed?
it would take some long term testing to see what mpg was actually doing.I removed it last night. My MPG actually went up this morning. Also there are two openings right behind the license plate bracket. It looks like it might be for cooling but only if you have diesel. The engine bay from bottom is all covered with plastic trim. So I think the openings are for the intercooler from diesel.
like was stated above just attach your plate directly to the bumper.Front grill camera. Now on the serious note. License plate bracket was loose like hell after I remove the air dam. Bottom of the bracket was attached to air dam. Maybe I'm wrong but will not take any chances this thing falling off and damaging my truck.
I dont know how your plate is mounted but there is no screws in mine to the air dam and it wont ever wobble...After removing the air dam I had to fabricate a bracket that attaches to the bottom of bumper and then bottom screws of the license plate bracket. Otherwise the bracket will wobble at high speed like crazy
What bumper did you go with?Mine is still attached to the stock bumper, I thought it definitely should stay attached to the stock bumper.
Because the stock bumper went to scrap!
F that airdam and its flimsy bumper
Hmm look again, or it isn’t installed correctly.I dont know how your plate is mounted but there is no screws in mine to the air dam and it wont ever wobble...
Two bottom screws are located behind the license plate. They were screwed directly to the air dam.I dont know how your plate is mounted but there is no screws in mine to the air dam and it wont ever wobble...
Yep this^Two bottom screws are located behind the license plate. They were screwed directly to the air dam.
I'm curious then why Magna made such a big deal about their active air dam on the 1500s, being all about reducing drag and improving fuel economy.the air dam is not for mpg although it can affect it in severe winds really its main purpose is to prevent a negative pressure zone behind the rad for cooling reasons.....
They are just push pins in the bottom air damn not screws but they hold nothing really i left em out when i trimmed my danmHmm look again, or it isn’t installed correctly.
You wild this morning. The air dam is 100% for mpg. It directs air around the hangy down parts like all other air dams everthe air dam is not for mpg although it can affect it in severe winds really its main purpose is to prevent a negative pressure zone behind the rad for cooling reasons.....
I will take a photo tonight. But on mine there were two long screws (same as the top ones) threaded directly into the air dam. It didn't look like it was designed that way but like someone just screw them in thereThey are just push pins in the bottom air damn not screws but they hold nothing
They do but its so minimal there are wind tunnel tests proving the millage increase would be very hard to tell in normal conditionsI'm curious then why Magna made such a big deal about their active air dam on the 1500s, being all about reducing drag and improving fuel economy.
On trucks without the front plate holder, There are two dimples in the air dam to locate the screws and “anchors” behind the dam. They’re definitely supposed to be there.I will take a photo tonight. But on mine there were two long screws (same as the top ones) threaded directly into the air dam. It didn't look like it was designed that way but like someone just screw them in there
Hmm maybe they were screws i thought they were push pins but its been a while and i threw em out lolI'm going based off of memory (which isn't all that great any more), but I don't recall my bracket being screwed into the air dam. I do believe it had some bracing though that pushed up against it, which is why I ditched the bracket and just bolted straight to the bumper.
