Oh come on. Every manufacturer have issues with some of the cars. It's normal.Maybe I should cancel my order and stick with my Toyota if its that bad...
Case Number: S2108000009 Release Date: 1/13/2021 Symptom/Vehicle Issue: RKE Does Not Unlock The Doors After A Remote Start Event Discussion: After a successful remote start event the vehicle’s RKE does not unlock the doors. This issue may be intermittent. Engineering is aware of this concern is currently anticipating a TSB software update be released during the 1st quarter of 2021. Replacement of RFH, Fobik’s or any other components WILL NOT resolve this customer concern.
Case Number: S2108000009 Rev. A Release Date: 1/22/2021 Symptom/Vehicle Issue: RKE Does Not Unlock The Doors After A Remote Start Event Discussion: After a successful remote start event the vehicle’s RKE does not unlock the doors. This issue may be intermittent. Engineering is aware of this concern is currently anticipating a TSB software update be released during the 2 nd quarter of 2021. Replacement of RFH, Fobik’s or any other components WILL NOT resolve this customer concern.
Yeah it sucks but I don't say RAM is crap just because I have an issue. This is my 4th RAM and actually first one brand new and first one with a problem like that.Yeah, but it sucks when you are the one with the issues (As you are aware)!
1500 classic, or 5th gen? The classic uses a different RF Hub manufacturer. The 5th gen uses the same RF Hub manufacturer as the 2019+ HDs, but different part numbers and software. The 5th gen 1500’s aren’t without issues, either. They are very sensitive to interference from LEDs when they are installed in the CHMSL, and they don’t like to remote start the truck in cold weather (although, I believe that is more of a battery voltage threshold issue).The thing that makes no sense to me is my wife has a 2020 ram 1500 and the fobs are different than mine. Either way hers unlocks. I wonder what the difference is between the 1500 and the hds
I wonder if it is the LED's that is causing the issue on mine as lights come on when started.1500 classic, or 5th gen? The classic uses a different RF Hub manufacturer. The 5th gen uses the same RF Hub manufacturer as the 2019+ HDs, but different part numbers and software. The 5th gen 1500’s aren’t without issues, either. They are very sensitive to interference from LEDs when they are installed in the CHMSL, and they don’t like to remote start the truck in cold weather (although, I believe that is more of a battery voltage threshold issue).
5th gen1500 classic, or 5th gen? The classic uses a different RF Hub manufacturer. The 5th gen uses the same RF Hub manufacturer as the 2019+ HDs, but different part numbers and software. The 5th gen 1500’s aren’t without issues, either. They are very sensitive to interference from LEDs when they are installed in the CHMSL, and they don’t like to remote start the truck in cold weather (although, I believe that is more of a battery voltage threshold issue).
I know I'm all late to the party but I saw this kit from NISMOPAR for full passive entry kit. Anyone used this and does it seem legit?
It’s legit and all factory parts, but the door harnesses and jumper harnesses are a little excessive, and add about $200 to the cost of what you can do it for. If you source the handles and antenna yourself, I offer a pair of harnesses for the handles that will integrate right into your existing door harnesses. @kristof installed passive entry using my harnesses.I know I'm all late to the party but I saw this kit from NISMOPAR for full passive entry kit. Anyone used this and does it seem legit?
2019-2023 Ram 2500 3500 DJ D2 HD Add Complete Passive Entry Kit
Due to the multiple configurations available we need your VIN. Free ground shipping for 48 Continuous States. Only to lower 48 Statesnismopar.com
Yeap. Works like a charm.It’s legit and all factory parts, but the door harnesses and jumper harnesses are a little excessive, and add about $200 to the cost of what you can do it for. If you source the handles and antenna yourself, I offer a pair of harnesses for the handles that will integrate right into your existing door harnesses. @kristof installed passive entry using my harnesses.
What? I don't know what are you talking aboutAnyone else have an issue with theirs ye
his post was merged to this thread.What? I don't know what are you talking about
No there will not be a fix until the second quarter as per the star case mentioned here.I've just read all 18 pages and no one is saying their truck is fixed, wth. Like reading all of the book except the last chapter. Did anyone get resolution?
That wont work they will just wonder why you didn't use the physical key lolI believe Ram Cares has responded they do not have any power when it comes to pushing a recall or update. they just basically ask your current dealer to play nice. It is going to take someone being mugged and beaten in a parking lot because their truck wouldn't open. Any volunteers??![]()
