DataPak420
How hard is it to put that floor console in? I would like that have that one in my 2020.I was designing a bracket behind the battery in the OEM Aux PDC location for the power module, then I was planning to put the keypad on my lower center console behind the transfer Case shifter(I installed the 4th Gen floor console so I have a bit more real estate to work with than the standard 5th Gen which is just carpet)
But...
I saw SDHQ released a power Module bracket that goes by the main PDC and laser cut replacement panel for under the stock light knob, so I ordered them instead.
https://sdhqoffroad.com/collections...500-sdhq-built-switch-pros-power-module-mount
'19-Current Ram 2500/3500 SDHQ Built Switch-Pros Keypad Mount
SDHQ Built Switch-Pros Keypad Mount for the 2019-Current Ram 2500 and 3500 allows you to mount the keypad component of the Switch-Pros SP-9100 or RCR-Force-12sdhqoffroad.com
Sent from my SM-N960W using Tapatalk
