Industrial Injection CP3 pump and installation and follow on use!
Thanks man
We will get it done bud. I’m a bit slower than the 4 hour mark but it will be solid when it’s in.
I take longer to do stuff too because I tend to work slow and methodical so I don't miss anything.
As to working space, I had a helluva time installing a vacuum pump on my 04.5 when I installed a Banks exhaust brake, including having to spend hours searching for the stock banjo bolt that I needed to reinstall in the CP3 so the vacuum pump would clear.
I had used a longer one to add a fuel pressure gauge setup and while I'm usually good at saving spare/takeoff parts, it took me hours to find that damn bolt.
Woo-Hoo! Can’t wait to hear it run.
So she runs
And drives
But she is dumping fuel from the rail. Man I though I had those tight and doesn’t at idle so it’s only at high pressures.
Hmmm
Awsome I know pics and write up will be coming.... If you happen to take cp4 apart we want pics if it looks scarred or anything
Hell ya, glad to hear it's done. Didn't seem like you had too much trouble.
Nice work
Thanks everyone
I’ll do a post process write up soon. Photos were tough to come by cause everything required hands.
But we will get it done. I’ll augment the instructions where I can.
Did u just have to tighten the rail more to stop the fuel leak?
Yes.
I took both high pressure fuel lines off and re did them from the rail and connected them at the pump last. The rear one (closest to the firewall) was what I suspected of being loose. I took both off and repositioned them and really got a good wrench on em. You really gotta reach for that rear one and they have to be super tight.
Ok write up time.
It’s not as helpful as a video or a plethora of photos step by step but I hope it’s an augmentation of the instructions so let’s do this. You’ll use my notes.
First and most important, tools.
Here is the breakdown
2 new fuel filters
Impact (larger one worked great for the 26mm to break the gear nut)
Gear puller
H6 hex socket head
Sockets (shallow and deep) 15mm, 13mm, 10mm, 8mm (maybe a 9 shallow), 26mm and 1-1/8
Ratchets (3/8 and 1/4 helped me) short and long
Blue loctite
Fastener remover (red handle)
MANY extensions (short snd long)
A few swivel extensions
Wrenches 3/4 (standard and stubby), 3/4 ratchet head adapter, 5/8, 10mm, 3/8, 13mm
Snips (cut sharp zip ties)
Flathead screwdriver
Lighting option (if you can move it around like the Milwaukee I have shown that’s ideal)
Torque wrench
Small pry bars
High temp electrical tape (optional)
Magnet cause you’ll need it hahaha
Lucas assembly lube
Brake cleaner
Vice or a way to hold the gear of the CP4 (I had an old oil wrench that worked actually)
If I am forgetting something I apologize.
1) 10mm on both batteries. Wrap them in something. I used a microfiber towel
2) easy to see on the top there are (4) 8mm bolts. Remove your dip stick to remover the cover, replace when it’s off
3) talked with industrial they said I could skip it if I wanted to. For me it didn’t add that much more room.
4) this thing doesn’t want to come out and you can skip it. However I pulled mine half way and cut it to have more access. You’ll want to undo the large connector on the top of the engine bay. Look at the fire wall and you’ll see it. A good time to move some of the clips and connectors holding wire harnesses in.
5) I used brake clean Amsoil. Low pressure are black and are push tabs while pulling. High pressure is 3/4
6) blend of step 5. Note the low pressure fuel line connectors rotate in the line so don’t worry about them you won’t hurt them.
