Industrial Injection CP3 pump and installation and follow on use!
Here ya go
On the pricey end
Traxion 3-100 Foldable Topside Automotive Engine Creeper https://www.amazon.com/dp/B00QGXSODA/ref=cm_sw_r_cp_api_glc_fabc_O6obGbCJ4TYXJ?_encoding=UTF8&psc=1
I have a plan to zip tie some microfiber rolled up towels where they make contact with the grill not to do damage. That’s my only gripe with these.
Thanks, I’ll add that to my long list ;)
Nordic let us know how that creaper works out I'm also in market for one but domt want a pos
It's not particularly comfortable (not that any of these are), and it when collapsed it isn't super easy to maneuver around, but it is well built, and holds my 240LBs while dangling over my MRR soldering track. This is the Micro-Mark version: https://www.micromark.com/Topside-Creeper-Step-Ladder-Support-System. Currently on sale for $270, you can sign up for emails and get an instant 10% off. They will sometime do a 25% sale, but not sure I've ever seen this that discounted, although I stopped checking on it once I got mine.
Morning gents. Gonna kick this off in the next hour or so. Hope it’s a smooth install. I’ll keep you guys updated on my progress, roadblocks and tricks if I have any along the way.
Awesome, take your time and enjoy the wrenching.
I'm sure it will go smooth
Are you done yet?
Pink isn’t even out of the truck yet haha but I’m close
Today kicked my butt gents. I got to the point of installing the new pump. Realizing I missed a step 4 steps back.
I ended up nicking up the adapter plate pretty good but what has me concerned is the adapter plate mounting holes to match the direction where the CP3 should be clocked. Needless to say I probably have something backwards but it’s locktite in right now so tomorrow will be fun. At least I used the blue stuff.
So the truck sits over night. I am tired and a little knocked down haha but let’s hope I can bust those loose and get it finished tomorrow.
I need to mount the pump, run the high pressure fuel lines and plug it in / connect the ECM and batteries. I have a good 3-4 hours left at my pace.
Blue loctite is effortless to break free
I’m glad to know that now haha.
It has been a great smooth day until this evening. Their instructions could be better, or well I could understand them better.
It’s a tight fit and the thing that takes the time is manipulating the tools and such.
Pretty beat tired but I have to get it done now.
The instructions are very straight forward depending on your skill level..... from what i see on the instructions and looking at the truck it should only be about 3-4 hrs round trip if your experienced wrenching.... you wont have to worry about the adapter plate marked up or not it does not make a difference aslong as the bore where the pump goes in is not beat up to cut the o ring (if it is you can clean it up with emerycloth) you will be fine
