ramblinChet
Drinks Alone
delete
Your way over thinking itDropping in and out of overdrive excessively, not being able to cruise in 8th gear with no load at 70 MPH, etc.
I though after 85 the cruise didnt work? Or do you mean km/hWell let's see, 2020 PW 6.4l w/4.10s obviously on 35"Nitto RGs and on a level interstate at around 2000ft I get 10.2mpg with the cruise set at 95 on a trued speedo. Does that help?![]()
Interesting as mine wont work past 85 same as a few others i know i was told ram did that for “safety” by the dealerCruise works just fine at 95 MPH.
ETA: my normal cruise is 85 in a 80 and I usually see around 12ish MPG, I've seen almost 14 but never over that on a flat calm 60 MPH...
Any info on where to source steeper gears for these trucks? I've been unable to locate anyone making 4.30 or 4.56-ish for 19+ trucks.Might want to post something in the Power Wagon forum... a lot of those guys are running 37's with the 6.4L and 4.10 axles. From what I've read I the 37's are fine with the 4.10 gears but definitely more sluggish than with the stock tires, I wouldn't go any bigger without regearing. Is this going to be an overland rig? 40's would be sweet!
Call AEV. I believe they put 4.88s in their upfitter trucks along with hydro assistAny info on where to source steeper gears for these trucks? I've been unable to locate anyone making 4.30 or 4.56-ish for 19+ trucks.
I've already spoken to Nitro, Yukon, and USA Standard. None of those currently offer R&P for 19+ HD Rams.I would say give Nitro Gear a call, sounds like that's who AEV is using.
That super60 thoNo worries. A little frustrating since they've been out for 2+ years now. I'm guessing it's largely due to the offroad (jeep, etc) world wanting the Ford super duty front axles over the Ram.
No doubt. If I weren't running Dynatracs in my TJ6 the SD60/14b would definitely be high on my list.That super60 tho
