I unfortunately discovered that there is no point in leaving a trip meter going to measure mileage over a long period of time. I had done so and discovered unbelievable results over time. It turns out it only goes back a little and then rolls over the data. Completely worthless. for anything but short term calculations. There is a discussion here somewhere on it. Maybe in this thread. If you want long term data, start a Fuelly account and be religious about keeping it updated. That is something I am incapable of doing.Update on my experience. I’ve been driving a different route with a lot less stop and go, the EVIC has improved to 14.4 mpg. I decided to leave Trip Meter A running without resetting to see the long term average from driving it off the lot new BUT I randomly reset Trip Meter B a week or so ago to see what short term trip results were. It was convenient today that they all were within a few tenths of a mpg when the low fuel light came on, the display showed 47 miles to empty. I drove 351 miles between fill ups and it took 26.19 gallons to top it off. That equates to 13.4 mpg when hand calculating. The previous fill up calculation was 12.8 mpg so that’s a .6 improvement over my last update. A small increase but I’ll take it.
View attachment 4619View attachment 4620View attachment 4621View attachment 4622
Edit: Found it. https://hdrams.com/forum/index.php?threads/vehicle-mpg-gauge.1408/page-2#post-15173 Only a 200 mile rolling average. If that is the case it isn't even accurate for a tank of gas (that might explain a lot actually) Totally lame if true. One thing that might explain is why your mileage seems to drop off at an accelerated rate after driving on the highway for a while and then going into city driving. Suppose you drive 200 miles at 17 mpg and then another 150 miles at 11 mpg. You are going to get a very bottom ended result of maybe 12 mpg when in fact you really got closer 15 mpg on the full 350 miles. Someone do the math if you want because that is just wild estimates.
