My 2019 2500 Power Wagon didn’t come with the LED Bed Lights and the dealer said they weren’t available as a kit from Mopar yet when I was buying it. Flash forward, the Mopar website now shows (2) kits for the bed lights that fit the 2019 and 2020 2500s. Same kit part number but different revision numbers. I bought the newest kit number but was shipped the old revision. Only differences appears to be the wiring, the new kit has two of the tan wire to reach under the dash or under the PDC (depending on 2500 vs 1500 Classic).
Anyways, after closely comparing all available install instructions and reading this thread on RamForum.com, the wiring I believe to be correct is green/white wire to under-dash connector C7 Pin 16, and tan/white wire to under-PDC connector C3 Pin 17.
Issue is, there is already a tan/white wire in under-PDC Connector C3 Pin 17. Has anyone else installed this kit? Is this wiring correct? Do I need to splice into the existing tan/white wire?
