Happened again this morning. I left my house remote started my car and as soon as I get close to it I press the unlock button and nothing. I had to use my emergency key to get in
Did you happen to install aftermarket LEDs in any exterior light locations that are lit when the truck is remote started?
Nope. I have only installed the remote starter and tailgate assist shock. Everything else it's stock. Could I screw up settings in AlfaOBD? At first I changed the CBC Features: Vehicle Theft Alarm (VTA) Hood Ajar Monitoring and I don't remember if it should be set to NO or YES. Also should I change VehConfig 8: Wired Remote Start Stop Feature Present to YES ?
VTA hood ajar monitoring wouldn’t affect anything, but you can set that one to no, since your truck will always think the hood is closed with the hood ajar circuit grounded with the resistor. VehConfig 8 wired remote is for cab n chassis trucks, different feature for commercial settings.
And I tried again after work and same thing. It looks like the FOB won't work at all for some time
Like there is a delay. I tried all buttons and none of them worked.
Just had this done today on my 2020 3500 Tradesman. Worked like a champ--used the link provided on here to order the key fob and requested the dealer to program the fob and add the sales code.
Appreciate everyone on this thread--saved me at least $500 on having to purchase remote start!
Thank you all for the assistance. Yesterday afternoon the dealer programmed my key FOBs and remote start is working now. When I start the truck with the key FOB the truck doors remain locked, (I wondered), and the truck remains in a remote start mode that you cannot just jump in and shift, as the shifter stays locked until you press the push button start to take it out of that mode. I can disable the beeping right with alphaobd? I am not for sure I will do that, but thinking about it. Dealer charged me about $67.00 for both FOBs and it took about 40 minutes from the time I checked in.
For the horn with remote start, use AlfaOBD to set CustSetMenu 1: Sound Horn with Remote Start CSM Present- YES
This will put the setting in the radio so you can toggle the feature on or off.
My dealer charged me $70 for one FOB. But I assume they will charge me same for two. It took them over hour and a half to do it. But they played with adding gate assistance sales code to it also. Can you unlock the door right after you activate remote start?
I am not sure what you mean if I can unlock the door right after I remote start it? I can unlock the doors after remote starting the truck, but I did not try it immediately after starting the truck. Mine is a diesel though and I have to wait for the preheat to finish before the truck will start and that takes 6-10 seconds or so. Do you mean like starting then unlocking one action after the other?
Yes. When I remote start my truck and try to unlock it few seconds later it will not unlock. I have to stand there for maybe 15-20 seconds and then I am able to unlock it.
Perfect Jimmy, thanks as always!
I can try it when I leave work tonight and post. I will let you know.
Thank You. There is another member who said have the same problem. Where did you order FOB for your truck?
I order from the same guy I always order most parts for my truck from Mopar Superstore.
I can post the part number I used, but it was a MOPAR kit though. Came with the hood hinge w/sensor, two key FOBs, some zip tie straps, a small wiring harness, a CD with the install manual on it, and that was about it I think.
Last night as I walked out to the truck I used the remote start and started the truck and immediately after starting the truck I unlocked the doors. No issues. I tried again this morning, and same thing; I was able to unlock the doors immediately.
Jimmy, I see the Cust. Set. Menu 1: Sound Horn with Remote Lock CSM Present. But they options are Feature 1 - 2 Option or Feature 2 - 3 Option. I don't see YES or NO as an option. Am I in the right area to do what I want to do with the horn?
That CSM is sound horn with remote LOCK (when you press the LOCK button on the fob), and should be 2-3 option.
You need to set the very next CSM- sound horn with remote START- to YES.
