Freshened up the rear hubs with a new coat of paint and new lugs on all 4 corners. I am able to use the center caps on the front wheels.The black lugs that I got new with my wheels were showing metal under the black coating out of the bag and it was just time to replace them.View attachment 94453View attachment 94454
Looks good. I was thinking about grabbing a new set of black nuts.. what nuts did you grab? My old set looks like your old set.
Truck is dirty but whatever. Truck is a 2022 so I needed to do some things as well as did some extras. On my way to the shop who does the work, my check engine light came on, ended up needing a new air filter. Then found a screw in the tire so had to get that fixed too. Had the oil and oil filter and fuel filter done also. Then after the parts below were installed I had it aligned to Thuren specs.
But here is what was installed.
- Thuren 1” front coils
- Carli shocks (stock air ride rear height)
- Thuren track bar
- Thuren sway bar
- Carli lifetime ball joints
- Edge EZX (just wanted to set TPMS levels mainly)
- Thuren track bar
- Thuren sway bar
You should add the Rear Track Bar. Makes a Big difference. Very Noticable improvement. Looks Good!
I look forward to a post crawler hauler tow and some seat time review as you have been contemplating it a while. I would almost be interested just to lose the $hitty factory tailpipe and resonator. The sound would be a bonus.
Towing up to Tennessee this morning and I’m pretty impressed. It doesn’t make any undesirable drone, frequencies, reverberations etc. Borla has the no drone figured out.I’m pretty sensitive to undesirable noise and I approve.
With 8k behind me the Hemi downshifts and screams up hills as we know and obviously the exhaust tone gets much louder as the engine works. for the most part on flat ground I can hear the duratracs over the exhaust. Going up hills the exhaust can get pretty loud as the engine winds up but it never drones
I made a video uphill then going flat for @dieselscout80 but I’ll have to upload it later
