Freshened up the rear hubs with a new coat of paint and new lugs on all 4 corners. I am able to use the center caps on the front wheels.The black lugs that I got new with my wheels were showing metal under the black coating out of the bag and it was just time to replace them.View attachment 94453View attachment 94454
Looks good. I was thinking about grabbing a new set of black nuts.. what nuts did you grab? My old set looks like your old set.
Truck is dirty but whatever. Truck is a 2022 so I needed to do some things as well as did some extras. On my way to the shop who does the work, my check engine light came on, ended up needing a new air filter. Then found a screw in the tire so had to get that fixed too. Had the oil and oil filter and fuel filter done also. Then after the parts below were installed I had it aligned to Thuren specs.
But here is what was installed.
- Thuren 1” front coils
- Carli shocks (stock air ride rear height)
- Thuren track bar
- Thuren sway bar
- Carli lifetime ball joints
- Edge EZX (just wanted to set TPMS levels mainly)
- Thuren track bar
- Thuren sway bar
You should add the Rear Track Bar. Makes a Big difference. Very Noticable improvement. Looks Good!
