Aisin shifts FAST, just doesn't feel "normal"
ErikTheRed
Sacramento-ish
The Aisin in my 2024 3500 shifts ridiculously fast, meaning when taking off from a stop, the damn thing is in 6th gear before I even make 40 mph. It runs through the gears, even under acceleration, faster than anything I've ever owned. Truthfully, it makes it kinda hard to have any "fun" with the truck off the line because its ALWAYS in-between shifts! It doesn't do what I'm used to with other vehicles, including my 06 5.9, which is to hold gears a bit longer and wind out a little under acceleration before it grabs the next gear. This truck? No. Get on the throttle (or not) and it just sweeps though all 6 gears blam blam blam. I feel like Im gonna hurt something when accelerating hard (which I don't do often) with it constantly shifting like that. Is this normal behavior for the HO/Aisin?
You bought the wrong rig if you want to have "fun." The 3500 high output with aisin is for towing. For fun, you honestly need a different vehicle.
That said, you can improve its pick-up by using tow/haul and deselecting the exhaust brake.
He isn’t wrong though.
The factory shift points on the Aisin are absolutely ridiculous. The truck is in such a rush to get into 6th gear.
I’m not defending the quick upshifting, but It’s done to improve fuel economy.
I have an International dump truck with an Allison 3500RDS that does same thing. It’s in 5th gear by 25MPH.
The “Big 3” are not just in HP wars, they’re also in MPG wars.
With the gearing in a medium-duty dump truck, that’s to be expected.
With the gearing in a 1 ton, being in 6th gear at 50mph is questionable at best.
It’s not medium duty. It’s a class 8.
But it’s done to keep fuel economy numbers as high as possible and to keep the low revving in line 6 ~2,000RPM. If it held gears longer, it would rev higher, use more fuel, and wear the motor out faster.
Also depends on the rear ratio. Also it helps the engine last longer since it keeps RPMs low. 6.7Cummins doesn’t like to rev. It wants to keep the RPM’s low to keep efficiency at its best and wear at it’s lowest.
I’m not saying I like it. I’m saying the engineers at Ram make the truck upshift quickly to keep the accountants and penny pinchers happy on fuel consumption and wear & tear.
Mine has 4.89’s and get’s into 6th by ~50. I’m happy with that, because my truck was built to tow heavy. If I had 3.73’s, I wouldn’t be as happy.
I’m running 4.10’s on my Aisin truck, and I’m still not happy.
Can’t blame you.
Running your truck empty and having the truck in 6th by 50MPH isn’t much fun.
When I get a trailer hooked up, the shifting strategy changes completely and my gears are “held” longer.
When I get a heavily loaded trailer hooked up, it holds them even longer.
If I need to, I’ll just flip over to manual mode. I do this when holding a heavy load on a hill. I’ll pull out and hold first until I clear an intersection, then upshift, or flip it back to auto shifting mode.
IMO, the Aisin is a real tough, HD transmission, but could use some better programming/tuning, or maybe a customizable shifting pattern controller.
Use TH or reach out to PPEI for a tune.
I don't "hot rod" the truck, I actually almost baby it most of the time. Or at least, I drive it about like I do my car. But every now and then its kinda fun to give it the beans, like when merging into freeway traffic or taking off at a stoplight and trying to get in front of the goober in the next lane before the lanes merge into one. This is when the Aisin's rabbid shifting gets annoying. When the toy hauler is hooked up, yeah, it'll hold gears longer, as it should. Same when climbing hills and so forth, it pulls a trailer like a proper work rig. Otherwise though, the lightning-fast shifting is just not something I've experienced.... and in my 53 years, I've a had a few vehicles. I think I'll just deal with it rather than fuss with tunes and whatnot, really I just wanted to make sure that its acting like it was designed to act. If this is normal, then so be it.
