Grid heater bolt
That's frustrating on the warranty coverage for him. I had a little bit of a battle too as I did my own oil changes. To me, the maintenence is irrelevant for a grid heater failure. I understand for the lifter failures why they want oil records given the oil requirement change for the 19+ trucks.
Yea he tried making it clear the grid heater bolt has nothing to do with the oil changes but they are so much like robots these days its like talking to a brick wall..
I always document all my maintenance in the Ram app in addition to my own records. The dealership has access to all that information. I also keep copies of all invoices for maintenance items.
Yeah, I don’t see how oil changes, etc. have any bearing on the grid heater. That’s just a piss poor dealer cop-out.
I'm my case, supposedly it was STAR that required the oil records. Although, that could have been the dealership just saying that too.
Either way, it does just seem like an excuse to deny warranty for an unrelated reason.
I’m sure pretty much any manufacturer has an entire legal department whose job it is to justify denied warranty claims. It’s the same as insurance companies.
The less they cover, the better the profit margins.
Absolutely as well as they have engineers that design stuff to last past warranty but not much further. Thats why vehicles with longer warranty periods statistically last longer as they were designed to last.
At least with the grid heater bolt, it’s less crooked, and more of a “****, I did not see that one coming”.
Just a shame that they could find a way to justify denying a warranty claim on any motor that has nut/thread imprints on number six.
Its a shame they have not came out with a recall to fix the issue.
I've been reading on this topic. Seems there are a few ways to skin the cat. Can you guys elaborate just a little on the BEST way to disable the grid heater? And what's the deal with the "bypass wait to start"? This truck is push button start, so I'm not used to this on a diesel truck.
I just bought a '24 yesterday with 46k miles on it. The Carfax shows the first oil change at 13,530 miles and the next at 33,110 miles and the last at 46,184 miles. So in light of what I've read in this thread, I'm worried that a dealership may try to deny warranty coverage on my engine if the nut falls into the intake. I need to mitigate that issue until I can afford a Banks intake elbow.
Press the button twice when starting the truck, and this will bypass the preheat process, but won’t do anything for the post-start running of the grid heater.
You can completely disconnect the grid heater from power by removing the wire that runs from the passenger side battery, down to the grid heater relay. Stash it in the glovebox for a rainy day.
I personally just do the wiggle test on mine every time I get fuel, but I do understand that some want something a little more fail-safe than that.
I just went out and checked my 2024 and what I found looks different from the pictures of older trucks that I have seen. At the grid heater my connection is actually mounted to a pedestal. And then over on the passenger side it's connected to what appears to be a computer module rather than an old fashioned solenoid. Does this indicate that the 2024 models got an update? Or should I still disconnect this thing?
No “update” on the 2024 trucks.
That is the grid heater relay that you’re referring to.
That’s the grid heater relay. Yours is solid state. ‘07.5-‘18 are mechanical. There was a recall on some of the solid state relay years, don’t know if yours is affected.
I think the mechanical went up to 2020.
