Digital Rear View Mirror
That guide is a bit odd
If it’s not working then maybe try both switched ignition wires one at a time and if that don’t work then tie them together
Hey. I put 2 taps on the orange and red 12v power wire at the same time. Tested the with the volt meter and had 12 volts and mirror still didn’t turn on. I wasn’t sure if you can put two taps on the same wire. I tied one at a time and nothing. Very lost maybe the ground is not on right or a blew a fuse but I have power when the ignition is one. Tested it with the volt meter. So if fuse was blown probably wouldn’t get any volts. Feel very defeated.
put your test light ground on the ground wire you are using and see if you get 12 volts .
I don’t like those vampire taps as loose connections happen a lot
That’s what I did. I grounded the meter ground to the oem ground and tested the power cables. Got 12 volts when ignition was on. I don’t get it. I hope I didn’t wasted all that money. I didn’t have the battery disconnected. I hope that didn’t cause the problem. I need to test the gentex 16 pin for power. But have nothing small enough to get in the female pin connecter.
This might sound stupid but make sure the wire going into the vampire tap is actually going in and not going down the plastic side of the tap
Any advice is greatly appreciated not stupid. It’s funny because when I was taken a look at the connecters a couple weren’t centered. I hope I am dumb and that’s the problem. Not likely. To easy of a fix for me. I probably take a look at this tomorrow. Very defeated right now. I want to test the 12 pin connector. Need something small to fit in the female end.
Don’t worry I’ve done this before so that’s why I brought it up .
Let’s hope this is all it is .
Cheers
Cheers
Thanks. I bought a lead kit so I can test the gentex 12 connector. Comes tomorrow. I really hope I can get this mirror to work. With help from you and anyone else. I purchased wolfbox mirror and returned it for the gentex mirror. Probably should’ve kept it. Wife is going to kill me for wasting that kind of money if I have to get the wolfbox again. I like the oem look. Jimmy07 any suggestions.
So when you use this gentex mirror your side mirrors will loose the auto dimming function if you had that I’m guessing ?
I never installed it. I returned after buying the gentex. So I have no idea. When I drive my 26 I don’t even notice the side mirrors dimming. On my 24 3500 limited I noticed it. Strange. But if I can’t get the gentex to work I will probably buy the wolfbox. To get the 3.0 oem tow camera kit with the camera module is a lot of work to get a digital mirror working. I wish it was plug and play like before. On my 22 3500 I added the digital mirror. Very easy.
The 3.0 is very easy to install; I've sold many of them for the 23-26. It only requires power for the CVPM module of the mirror. I even installed it on a 1500
I've lost count of how many posts I've read about installing the DRVM in a normal auto-dim truck... I need help understanding what path I should take if I decide to do this installation.
My 2024 Laramie has the standard auto-dim three mirrors (oddly turned off at the factory, I just figured that out and turned it on with all the morons here using high beams all the time). Has the 360 system, no FCW, no adaptive cruise.
I understand 23/24 have a different system from older models that adds additional cameras in the sideview mirrors that I don't have (only the 360 cameras, not applicable).
I couldn't care less about the sideview mirror cameras, or CHMSL camera. With so many people crowing about leaks at their CHMSLs I'd rather not mess with mine anyway. All I want is an elegant trailer reverse camera system.
Obviously I don't have the input at the left of the plate in the bumper.
Is it possible to just get an older 21-22 mirror with 1-2 inputs, no FCW or adaptive cruise, program the truck so the autodim still works, and add the bumper connection? I can't for the life of me find posts from anyone simply adding the DRVM and bumper camera connection. No desire to go to the trouble and expense of the CHMSL cam or mirror cams or underseat module.
At this point I feel like it's all more trouble than its worth and I should get a standard wireless RV camera and screen (Furrion and the like) that I can tuck into the console when not towing and leave it at that, even if it means traveling with another screen like I wanted to avoid.
In that case, why not install the trailer camera system and have the images displayed on your 12-inch screen?
Meaning the cameras used by the 12 pin plug at the back? I could, but from what I've seen they're analog with low quality, and high price. Unless I'm mistaken, I couldn't use an aftermarket digital camera.
They use the same cameras as the surround view system. In fact, I'm selling a new kit that I wanted to install in my 2020, but I'm missing a lot of the wiring harness. These are the cameras.
You can use your own analog camera, but they're not going to stay on the screen while driving unless you installed a NAViKS NAV/Camera in motion box.
https://www.visionworkscameras.com/ makes a nice wireless system that plugs into the 12-pin.
That looks like a great option, and the price isn't too bad either. Do you use this system, or know anyone who can comment on how well it works?
hey all, here is a rough drawing of what I am trying to do. 2025 ram 3500 base truck. no power at the rear-view mirror. I have acquired the part numbers and are trying to test it out before installing in the truck. so far as shown in my drawing I have not got anything to come on the DRVM. am I missing something as far as how I am trying to test it. I assume you give 12 volt power to the mirror and 12 volt power to the camera module. the plan would be once confirmed it works , install and get the power for both the camera processor and the DRVM from a tap into the cigarette lighter on the top radio bezel. I am not that savvy on electrical stuff but get lucky sometimes. any thoughts would be appreciated good and bad. thanks PS. on the camera processor module the wires for the power to the module I have the two orange wires tied together receiving 12 volts +. The two white wires tied together receiving 12 volt -.
