Adding Passive Entry
Jimmy.
When I took off my rear door panels I do not recall seeing any antennas. Is it possible I am missing those and that is why the dealer could not activate the passive entry system. I do have remote and push button start
Would you be able to tell me the part numbers I would need for the door antennas and the console and rear cap antennas?
The dealer not being able to activate the passive entry system has nothing to do with missing parts. They can activate the sales code for features before any parts of the system are installed. The actual reason they can’t activate the passive entry system is because the GXD sales code is not available to them to add to your VIN.
52112203AB Are the two rear door antennas (56046957AA can be used instead of these, just like the rear bumper antenna).
68608685AA is the rear wall antenna. Not sure what the part number is for the one under the center console is.
Either way, those four antennas have to be present on your truck already in order for the push button start system to work.
@Jimmy07 id like to buy a set of harnesses check your pms
Anybody know the part number for the two front passive lock door handles New Holland blue color? Also who to purchase the wire harness from? I have a 2021 Ram 2500
Billet Silver 1UJ81JSCAI These 3 characters are the paint code "JSC"
substitute your paint code, and search one of the online mopar sites.
eg for my left front it is 1UJ81WCGAI superseded by 1UJ81WCGAJ , and currently not available ( back ordered )
where paint code is
"equipment_code": "PCG", or WCG
"equipment_desc": "FORGED BLUE METALLIC"
"New Holland Blue P72" , nothing found for 1UJ81P72AI , does it have a second code like my PCG\WCG , my PCG is not found.
I just got the rear antenna off of eBay. I don't have my door handles yet so I haven't installed anything. Is it OK to go ahead and connect the rear antenna or will it mess anything up? I have the rear wiring behind my license plate. I just figure if I don't go ahead and install it, I'll lose it by the time I get my door handles and do the install.
If you haven’t tried it yet it will give you a check engine light.
