stickshifter
Has anyone swapped out their stock axle shafts and U-Joints for RCV axle shafts?
A lot of the trails I drive involve steep rocky climbs with hairpin turns. The binding from the factory U-Joints is pretty bad. It makes me want to get out of 4-Lo and into 2-High, but its too steep to maintain traction in 2-High.
The RCVs are expensive, and will probably void my drive-train warranty, but I am seriously considering them. For those not familiar, RCV claims that their axle shafts are twice as strong as the OEMs when driving in a straight line, but they truly shine when you are making tight turns because they are much smoother than the OEM U-Joints and they do not lose any strength. When in a tight turn, the OEM U-Joints bind and hop, and they lose a lot of strength.
In summary: the RCV axle shafts will provide smoother delivery of power and much greater strength when making tight turns.
www.rcvperformance.com
Ultimate AAM 9.25 CV Axle Set for Dodge Ram 2500/3500 ('14-Up) with Disconnect
RCV Performance Ultimate CV Axles simply replace your weak Dodge Ram 2500/3500's AAM 9.25 U-joint axle shafts with a high-strength constant velocity design. Tests prove Ultimate CV Axles to be twice as strong as OEM axle shafts, and they're just as tough at a straight angle as they are at...
