Was Towing with my ‘17 6.4 today and my oil got hot, real hot, twice. I hit 280° on two separate grades, one at 87° ambient and the other at 105°. I was running just over 18K GCW. When the oil hit 280° the rpms were limited to ~4200.
Normal cruising on flat ground, same 18K GCW, coolant is ~204° and oil is ~245°. Highest coolant temp I saw all day was 222° but generally much cooler than that.
I even had a P1521, incorrect engine oil type, active after the first bump of 280° but not the second. It didn’t light the CEL but was active when I scanned. No dash warnings at all.
So I’m thinking the oil cooler isn’t keeping up and it’s time to replace it. How big of a job is it? The oil only has 1500 miles on it, but it’s getting changed after these temps. I’m using PUP 0w-40 and pressure never dropped, even with the temps, and held 53-55 (unlike my 05 Cummins where pressure would fall fast as oil got above 230° with aftermarket pressure and temp gauges).
Anything else I can look at?
