It would look better without the crossover tube and EGR valve lol.Did this!
Yes but Ohio has check and spa crapIt would look better without the crossover tube and EGR valve lol.
Yeah that 6K is why mine hasn’t been done.Yes but Ohio has check and spa crap
Plus roughly $6000 to do the delete
@foneguy, how long did it take you to install it? I have this sitting in my garage waiting for time to do. I have to work outdoors as the truck won't fit in the garage.Did this!
Even in the vast emptiness of Wyoming they're watching...Yes but Ohio has check and spa crap
Nice addition where did you obtain those caps.Good idea to help keep unwanteds out of tanksThis is my favorite thread on all the other forums I’m part of it. I haven’t seen it on this sight. If I’m duplicating, I’ll delete! But here is what I did today.
I put on Diesel Fuel and DEF caps and called about Ranch Hand replacement bumper I’m ordering.View attachment 4679View attachment 4681
You could have done the Vice Design hidden winch mount if not a fan of the bumperNew cheap Amazon winch bumper installed.
Would not recommend. Horrible gap, tortuous install, and need to trim wheel well liners.
When I remove it to put the winch on, I'll see about drilling new holes in the mounting plates so I can reduce the gap.
View attachment 86723View attachment 86724
What ditch lights did you replace?I replaced my Ditch lights with these Auxbeam lights.
One of my buddies in high school that I had known since 6th grade had a 1964 Galaxy with 3 on the column.Used 4lo for the first time to free a classic car from the Idaho dirt. Been sitting for 10+ years in the same spot.
View attachment 88357View attachment 88362View attachment 88361
I love the body style, and I can have the car for a family discount of $1000, but I just don't have the time or space to fix it up. Rat Rodding it would be cool, and the only viable financial option since the entire interior needs to be gutted, and a proper restoration would be easily over $50k, with already restored versions going for under $40k.One of my buddies in high school that I had known since 6th grade had a 1964 Galaxy with 3 on the column.
I'll have to look into that...Tail gate shock.
Nice, but not needed. As I pointed out in the video, the soft shackle, rated at 42k lbs, was wrapped through both breakaway attachments and around the hitch. My gear is anchored by far more metal than a 5/8" hitch pin rated at 12,500lbs.
