Did 400 miles towing the 5th wheel this last weekend and I'm impressed with the 6.4/4.10 combo. Aside from the wife's JT and a smaller TT I haven't towed anything with a gas motor in a LONG time. The 6.4 has plenty of power, even up to 7K feet.... but it does like it's rpms. I'd guess the 5th wheel was around 9K lbs and the truck was mostly empty. I got 8.4 mpg on the way up. Last time I towed the 5th wheel up to that area the '22 got 8.8, but didn't get the last 50 miles of gradual downhill and was loaded a little heavier.
Couple positives for the Hemi, the lighter front end it very noticeable on winding mountain roads. It just seemed to want to corner faster and easier and it doesn't even have the front sway-bar installed.
The downshifting on the 66RFE when the speed is reduced with cruise control is much better than the AISIN. On the 66RFE if I take the cruise from 55 to 45 the truck will downshift on its own, the AISIN's didn't.
The engine braking is very good, at least at the GCW I was running. I went down the hill shown below (return trip) at the 90 mile mark and never touched the brakes. Cruise set to 45 and let the truck do its thing.
Then there is the NA motor at altitude drawbacks and the truck defiantly worked harder to maintain 70 at 6500' on flat ground in 75° temps, but I did expect that.
I haven't fueled up from the return trip yet, but I likely broke 10 mpg.
All in all I can't complain about the truck or how it tows. The truck certainly performed better than I did on my 55K run
