Mine is in Pre-opp right now. Just have to wash/ blow out the engine bay and flash the puter.
It would be bright silver if deleted off the lot. No soot or dirt whatsoever as long as the air filter was maintained. Ccv does not help the cause either. The engine is ingesting its own blowby and exhaust causing that black cake batter. I’ve never manipulated a piece of egr soot that thick to know if it would scar a cylinder wall.Seems like another reason to fully delete all that crap. I wonder what one would look like if it was fully deleted from the first mile and ran under the same conditions for the same mileage? Is there any risk of chunks of that breaking loose and destroying cylinder walls or pistons?
Yep, SO engine here. I was thinking the same about that discoloration on the crossover tube - there has been some serious heat in that thing over the years. Luckily now it is just there for decoration for anyone who should choose to inspect it.Man that’s gross. It looks like your truck is a SO? I have noticed my crossover tube is purple like yours as well, indicating it’s gotten pretty hot. HO owners seems like their pipes aren’t as discolored. I think it was myself and @AH64ID discussing a while back if one uses more egr than another. Do you tow a fair amount of weight?
Yep
What wheels do you have?UPS dropped something off
17” method 315’s at -25What wheels do you have?
There is a huge plastic baffle in the intake tract going to the turbo after I removed it I have noticed .4 mph better and if feels Less laggy maybe it’s placebo..What baffle?
There used to be a muffler with foam that would help quiet intake noise, I guess that’s the modern version of it? Any increase in turbo whistle or exhaust brake rumble?There is a huge plastic baffle in the intake tract going to the turbo after I removed it I have noticed .4 mph better and if feels Less laggy maybe it’s placebo..
Most of the time would be for a cycle carrier, also as a front support for a 16' canoe, as I plan to upgrade the trailer to a fith wheel so would need canoe forward of the rear axle.What do you use the front hitch for?
The local BBQ supply had charcoal 50% off. I'm not sure how you guys get any work done with a 6.5' bed....
I have one for parking/positioning trailers In Tight spaces. It the only way I can get them in. Access is restricted. Also allows me to use the winch to pull stuff up on the trailer.What do you use the front hitch for?
