Trailer tow hours.
Outback32
I've searched and searched for this does anyone know how and when it records. On my new ram beside the trailer tow hours is just 2 lines like this -- no numbers just lines.
Fill your sig out and/or include specs on your truck.
Mine starts to tick when you plug a trailer in and then stops ticking whenever I unplug it. Not sure what the actual purpose of it is.
It would be neat if it assigned different miles to different trailers. Mine logs our camper just the same as a 200# tow behind post hole digger.
You should be able to select different trailers.
I towed my 7 pin tandem boat and mine still shows 0.0
Does it have electric brakes or surge brakes? More boats have serge brakes and uses the reverse pin of the 7 pin or 5 pin ti lock out the master cylinder for reverse.
Without electric brakes the truck does not know a trailer is connected and wont log miles
My truck is a 22 2500 tradesman. I think I seen someone say if the trailer has brakes it will register. That makes sense because my boat trailer doesn't have electric brakes.
