NO LONGER AVAILABLE: Looking for a Part Number? Must provide VIN (only up to model year 2020 at this time)
Status
Not open for further replies.
I have been searching everywhere for this, found it on a 2019 RAM 2500 3C6UR5NJ0KG593063
Looking for the part numbers for the instrument panel lower 115v power outlet and mounting plate.
Also looking for the rear center console mini-usb (type c) usb ports and 115v power outlet and mounting.
There should also be a cable that connects the instrument panel lower usb ports to the rear usb ports.
Thank you
Raul
I'm not sure I was able to get exactly what you were looking for, but hopefully this helps.
I may not have had a proper vin, can we try 3C6UR5KJ0KG654044
I also may have misworded my question.
This if for a RAM 2500 without the center counsel (my bad), it has the 40/20/40 front bench seat.
Looking for the part numbers for the instrument panel center lower right 115v power outlet and mounting plate or bezel. See attached image circled in blue
Also looking for the mini-usb (type c) usb ports and 115v power outlet and mounting or bezel. It is located on the back of the center potion of the 40/20/40 bench seat.
There is also a switch that is titled Instrument Panel Power Inverter Switch and the Bezel the goes with it. It is located on the drive side lower left. see image attached from the owner's manual.
And interested in the part number for the Exterior Power Inverter, located on the driver sided of the bed.
This has been tricky...I think I found the 115V power outlet, USB ports, and cable. I couldn't find the truck bed located power inverter on the VIN provided, but I did find this part removing the VIN filtering. I've attached both of these. The one titled "525.02 - POWER INVERTER OUTLET Lower Dash and Center Console Outlets" has an image of the center console, but ignore the image - the listed parts are for the Lower Dash also. I also included all of the parts listed for this VIN's upper and lower instrument panels in case it has the bezels you're looking for.
Thank you,
I'll be looking through everything that you sent.
I'll also try to find a vin with the bed power outlet.
I found a better description:
If equipped with a front bench seat, the inverter is located to the right of the center stack, just below the climate controls.
Center Stack Power Inverter (If Equipped).
Is there a breakdown of the information that is in the "Remarks" column to figure out what they mean?
I just don't want to order the wrong part numbers due to no refund or exchange of electrical components.
Thanks again for all the help.
Thank you,
The remarks column on these are the sales codes that apply to the particular part/configuration. You a can find most of the sales codes here. Some of the product brochures have them as well if it's not listed there. Also, something to consider is if your truck has the underlying wiring needed to add these items. Depending on your existing wiring, it may not be a simple plug and play. You would need to check out the wiring diagrams in Tech Authority to confirm. If not, you would need to add the wiring with appropriate terminals.
I swapped my 2021 Ram folding seat for a 2013, 60 40 folding seat with the fold flat option. Unfortunately it was a junkyard find so I don’t have the VIN number. I am looking for the plastic bezel that surrounds the cup holders on the fold flat part of the seat. Any part number would be appreciated!
I will post pictures soon.it’s two pieces and it surrounds the double cup holder, but it’s mounted to the fold flat floor platform and the bezel surrounds the cup holder in the floor so you can still use it. The seat was a perfect fit for my 2021, I wanted the 60/40 folding seat with the fold down armrest. The fold flat platform was a bonus. Thanks
Hopefully one of these has what you're looking for...
Thank you 01Time! We have company from Chicago all this weekend and my iPad has zero memory so I can’t quite get to those pictures/part numbers. Once they leave I will check them out. Thank you for taking the time to help me out! I will circle back and let you know soon!
Looking for the gaskets that seal the cab lights and antennas on my 2020 Ram 2500.
Vin# 3C6UR5DJ7LG223246
Thanks
Attached is the full parts listing for 505 - FRONT SEAT, BUCKET. There are multiple part numbers, most differentiating by color/material. But there are some indicating sales code CAJ (Seats - Ventilated Front).
Another question related to this: are you able to provide the part numbers for the wiring harnesses required for the heated & ventilated seats (which should also include heated steering wheel)? Should be same CAJ sales code as everything related to the heated seats is included in the ventilated seats. Also, the Comfort Seat and Wheel Module (CSWM) under the driver's seat. Should be part of that list I would think. Thank you!
Thanks
I'm not finding a gasket in any of the parts diagrams...I'm guessing the gaskets may be integrated into the lights/antennae? Or maybe it's RTV? Attached are the related parts lists.
Attached is the parts list/diagram for the seat wiring with sales code CAJ, the module, and the steering wheel wiring harnesses.
Thanks for this. I had been told 68530206 was the correct part for the seat and wheel module, but your documents list it as 68388905. Quick search had the 0206 listed as a replacement for 8905. Is that all it is or is there a difference? Thanks for dealing with my pestering.
In my experience when one part number is listed as a replacement for another, they can be used interchangeably. The database that I get my info from hasn't been updated since Sept-2020, so it's not likely going to have the most current revision or part number if it's been superseded. I don't have any affiliation with Ram or access to more specific data, so I can't guarantee 100% fitment. But, if I was shopping for my truck, I'd probably be okay with either part number.
I’ll take stab at this. For 2022, it seems that the trailer hitch lamp is standard on all trucks? I can’t find any sales info that clearly states this, but, all the 2019-2021 tailgate handles are the same part numbers for their colors and cameras, and 2022 has a completely different set of part numbers. Here’s the list of 2022 handle part numbers below, and these are the sales code meanings:
MNA= Black textured
MNK= Body color
MNE= Body color with chrome
XAC= regular backup camera
XAK= surround view backup camera
XJJ= locking handles (standard)
Positions 7 & 8 in the part number define the color of the handle. Example: PAU is the paint code for granite crystal metallic. Drop the “P” in all the part numbers, and 7KJ43LAUAA is a granite crystal handle.
So, according to that list, the tailgate handle part number that you and g00fy have is for a black textured handle that accepts the hitch lamp and REGULAR backup camera. A black textured handle doesn’t exist that accepts the surround view backup camera.
For the tailgate handle jumper wiring, same as above- new set of part numbers for 2022 (*presumably* containing the lamp connector now).
Harness for regular backup camera equipped- 68521315AA
Harness for surround view backup camera equipped- 68521314AA
I’ll keep looking, but so far, I’m not seeing the part number for the lamp itself.
Do you happen to still have that 2022 tailgate handles Google doc? The link isn't working
I have a question. could you tell me the difference between outside mirrors: 68361478AC and 68367432AC? thanks.
3C63RRNL2LG187730
Looking for those two parts:
Wheel Bearing Seal (#12)
Axle Shaft Gasket (#24)
Thanks!!!
68367432AC is specific to the cab chassis, with sales codes:
GU3 (BLACK/POWER/HEATED/SIGNAL/PUDDLE/RUNNING LIGHTS/TRAILER SPOTTER)
XAK (SURROUND VIEW CAMERA SYSTEM), and
LFX (CONVEX AUX MIRRORS, POWER-ADJUSTABLE).
68361478AC is for the 2500/3500 (D2/DJ), with sales codes:
GPH (POWER BLACK TRAILER TOW MIRRORS - NIGHT EDITION),
XAN (BLIND SPOT AND CROSS PATH DETECTION), and
XAK (SURROUND VIEW CAMERA SYSTEM).
Hope this helps.
3C63RRNL2LG187730
Thanks!!!
#12 was filtered out when I used the VIN and #24 says non-serviceable part...attached is the full parts list for the illustration. Hope it's helpful.
Status
