Bigdawg3500
I found a Ram part number-68476026ab. My vin is 3c63rrglxkg578491. is this compatable for my 2019 Tradesman 3500?
See attached.Looking for the parts needed to add heated/ventilated seats, just fronts for now. Looks like it is different foam and possibly different seat covers with the ventilated option, and from what I understand it is only the "bag" needed for both heat & ventilation (4 total, 2 for each seat)? Also need a total of 4 blowers, 2 for each seat. And a module for each maybe?
I believe this truck has both options: 3C63RRJL5KG515663
Tyvm! Any chance you can tell if it's different covers (front seat back & front seat cushion) specifically for the heated seats/ventilated seats? I'm curious about whether or not I can just change the foam in my current seats and still use the same covers.See attached.
I'm thinking it's mislabeled 'Converter, Catalytic Selective Reduction' at callout#16 (68267075AE), since the SCR is #7 (68296341AE), also labeled as "Converter, Catalytic Selective Reduction'?Hi,
My vin is 3C63R3EL6LG215297. I'm looking for the part number for the exhaust filter for my truck.
Thanks.
Jeff
Thanks a lot for looking it up!! so you think it should be #7? 68296341AE? it looks like it. when I google that part number mopar.com says under description that it's the diesel particulate filter.I'm thinking it's mislabeled 'Converter, Catalytic Selective Reduction' at callout#16 (68267075AE), since the SCR is #7 (68296341AE), also labeled as "Converter, Catalytic Selective Reduction'?
I don't want to tell you the wrong thing. My AllDataDIY subscription lapsed, otherwise I'd check there for you to confirm. I'd call a dealer to verify before ordering anything to be sure.Thanks a lot for looking it up!! so you think it should be #7? 68296341AE? it looks like it. when I google that part number mopar.com says under description that it's the diesel particulate filter.
Rear suspension components attached.How about the rear anti sway bar and bushings and clamps, for VIN 3C6TR5EJ8KG528652 ? TIA
Thank you very much!Rear suspension components attached.
I'm out of town until later this week. I'll look it up when I'm back home.Can you provide me with the part numbers for the rear seat latch plastic insulator near the top of the seat.
3C6UR5DJ7LG223246
Attached are all of the items I found associated with the rear seats...Can you provide me with the part numbers for the rear seat latch plastic insulator near the top of the seat.
3C6UR5DJ7LG223246
My computer decided to stop working so I'm waiting on parts to get it up and going. Not sure how long it will be out of commission as I'm trying to turn this into a positive and upgrade it while I have it apart. As soon as I get it back going, I'll get this for you.My vin is 3C63R3EL6LG215297. I'm looking this part on the driver's side fender behind the rear wheel. I hit a piece of retread on the freeway and it was nice enough to do this and bust the folding step...dang it!! Thanks jeff.
Ps thanks for the exhaust filter info. Got a new one installed!
Sorry for the delay @LBC_Jeff ...here ya go.My vin is 3C63R3EL6LG215297. I'm looking this part on the driver's side fender behind the rear wheel. I hit a piece of retread on the freeway and it was nice enough to do this and bust the folding step...dang it!! Thanks jeff.
Thanks!Sorry for the delay @LBC_Jeff ...here ya go.
